Author Topic: I have this Menards "Tool Shop" Multi-use cutter....think it could route?  (Read 5973 times)
y2kgtp
  • Last login:June 09, 2008, 02:02:40 pm
I bought this a while ago, works good as a roto-tip type tool.  1 speed = 30k RPM
Think I could use router bits in it?  I'll prob go to Menards in a day or so and ask someone
who actually works there, but if I don't have to buy a router to do T-strip cuts, I will be
happy.
TOK
  • The Game Always Wins
Looks like a standard 1/4" collet. As long as the motor is strong enough, I think it'd be OK. Some of the major companies have these and sell as just laminate trimmers. They're less bulky than a router but weaker motors.
y2kgtp
Right, 1/4" I believe it is.  As long as it can use a 1/16" (1.6mm) slot cutting bit, that's all I care about. :D
shardian
It would slot cut just fine. I don't think I would go flush cutting 3/4" material with it though. It would burn up.
y2kgtp
Perfect.  1 less tool to go out and have to pick up.  I'm sure the 1 bit is expensive enough.....
sstorkel
  • Last login:November 08, 2011, 09:04:03 pm
30K RPM is pretty damn fast to be spinning a slot cutting bit! This tool is designed for small, straight bits. My router maxes out at 25K RPM and you can bet I don't run a slot cutting bit at anything close to that speed. Expect your wood and your bit to get burned if you run them at 30K RPM for very long...
y2kgtp
Good thought there.  I guess I can check to see how much a variable speed router is....I never really liked the idea of the 0-30,000 RPM.....especially when I have snapped a roto-zip blade before....
Looking at this option as well =
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=43060
y2kgtp
I ended up ordering a 2HP Variable Speed Plunge off of Amazon today for 59$ shipped:
http://www.amazon.com/gp/product/B0000C6DXZ
Also ordered some router bits for 26$, just to play around with:
http://www.amazon.com/gp/product/B00006F702
And finally ordered the 1/16" slot cutting bit for 16$ shipped from www.mlcswoodworking.com
