Author Topic: A few questions on MAMEing a cab.....PLEASE@@!!>>??  (Read 1897 times)
borals
  • Last login:March 07, 2020, 05:51:14 am
« on: May 16, 2008, 01:36:25 am »
Hi All,
I'm new to all this and have just started work on MAMEing a cab.
I live in Tasmania, Australia, so it was quite hard to get hold of one. I finally ended up getting two, one for myself, and one for a mate.
They were both in pretty bad shape, but I have gutted both of them and cleaned the one I intend to use up.
I have an old TV that I am using for the monitor, and  I have fitted it in the machine using some metal fixtures. That is connected to a pc via a TV out.
I'm fine with how to do most things but I just have a couple of questions regarding the control panel.
I was hoping to have a 4 player CP with no trackball or extra joys. So  just 4 joys with 7 buttons for p1 and p2 and 4 for p3 and p4.
Here's my questions:
1) I can get locally HAPP, MCA or SANWA joysticks. I assume that it comes down to personal choice and I was leaning towards the SANWA (j-stick with ball top). Any other info to help my decision would be fantastic.
2) I was going to make the CP 1200mm (approx 47") long, is this enough to comfortably have 4 players playing. Also how far apart should I have p1 and p2?
3) I was just going to get the standard dimple arcade micro switch, does brand matter?
4) Finally, I wanted to make my CP out of MDO after reading a few different threads, but I cannot find anyone who sells it. Does it go by other names? Is it just an American thing? Is there a different name for it in OZ?
Any help/comments are very welcome.
Cheers, borals.
« Last Edit: May 16, 2008, 07:26:53 am by borals »
Jack Burton
Re: A few questions on MAMEing a cab.....PLEASE@@!!>>??
« Reply #1 on: May 16, 2008, 09:43:35 am »
You would probably like the Sanwa best if you don't care for trackball games or 4 way games.  They are usually best for newer types of games.
lanman31337
  • Last login:January 10, 2024, 10:36:50 am
  • set to ludacris speed!
« Reply #2 on: May 16, 2008, 10:07:48 am »
Hi there.
I can answer a few questions for you.
#2 - my control panel is 47 inches x 19 inches.  It's great for 4 player action.
#3 - around here we use cherry switches, they seem to last well
#4 - you're looking for MDF - Medium density Fiberboard.
Kajoq
  • Last login:June 14, 2024, 11:28:46 pm
« Reply #3 on: May 16, 2008, 11:35:32 am »
I would definitely say get Sanwa buttons/sticks.  If you buy their parts you don't need to buy standalone microswitches as they come with them.
Jack Burton
« Reply #4 on: May 16, 2008, 01:13:07 pm »
If you do end up buying microswitches make sure you get soft switches that are made for gaming.  Industrial microswitches have a very stiff actuation that will make your hands hurt after a while and hurt your gameplay.  Also be careful of cheap joystick knock offs because they usually come with the aforementioned microswitches.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #5 on: May 16, 2008, 03:16:13 pm »
4) Not sure about OZ, but MDO (medium density overlay) might be under "laminated plywood".  MDO is not MDF.  It's better than MDF: lighter, stronger, outdoor grade, and paints as well as MDF.
Robin
Knowledge is Power
borals
« Reply #6 on: May 16, 2008, 09:23:53 pm »
Cheers guys!
Awesome. Heading to the hardware >.<
