Author Topic: Pop from speakers on boot and shutdown  (Read 1931 times)
jhabers
  • Last login:August 09, 2019, 03:29:34 pm
« on: May 14, 2008, 11:08:35 pm »
I get a pop from my speakers (computer speakers) from my Mame cab right when I turn the cab on and when it shuts off. Any way to address this? I have it hooked up to a smart strip. Is there any kind of inline filter that will filter this out? Not a huge deal but what the heck, would be nice if it didnt do it.
Ginsu Victim
  • Comanche, OK -- USA
Re: Pop from speakers on boot and shutdown
« Reply #1 on: May 14, 2008, 11:36:14 pm »
I like it. It's part of the machine POPPING to life. It also let's me know everything shutdown okay if I hit shutdown and walk away.
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
« Reply #2 on: May 15, 2008, 11:08:52 am »
Not really. Depends on the speaker type I guess and the quality of your powerstrip. I'm sure there's an electrical answer/solution, but as long as you're not blowing things, I wouldn't worry.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #3 on: May 15, 2008, 02:11:05 pm »
I think it's fairly common for speakers to pop on computer startup and shutdown, even if the speakers are always powered.  Two of my last three computers, and one of my parents' two computers pop.  I've always thought it was a speaker and/or sound card thing, as I moved my decent 2.1 speakers between the two that popped.  The only action I did was turn down the volume before shutting down, if anything.  Bugs me less than the windows startup sound (I disable that).
Robin
Knowledge is Power
jace055
  • Last login:August 22, 2025, 09:32:12 pm
« Reply #4 on: May 15, 2008, 02:27:47 pm »
Are you using onboard audio?  If you and a PCI audio card around switch to that.  I have notived that my onboard audio will do it but not the PCI soundblaster.
Ginsu Victim
« Reply #5 on: May 15, 2008, 02:41:43 pm »
My PCI soundblaster does it, though.
« Reply #6 on: May 15, 2008, 03:07:43 pm »
Sounds like your computer speakers are the amplified kind.  No way to stop the 'pop'.
ivwshane
    • My first mame cab! (WIP)
« Reply #7 on: May 15, 2008, 03:18:06 pm »
If I plug my speakers into a pci sound card (audigy 2) they make the sound, if I plug them into the on board audio, they don't make a sound.
So my guess is that it isn't the speakers but rather the sound card.
