Author Topic: Finishing control panels?  (Read 2631 times)
Lilwolf
  • Last login:June 08, 2026, 09:58:06 am
« on: May 12, 2008, 08:21:24 am »
Ok, redoing some control panels.  And my last control panels had black vynal sticky sheet on it.  Looked great and worked for 1/2 year or so, but after a while, it got scratched, then dug up... and this was adult used only, very limited damage... IE not a great long term solution.
So, how do I make the control panels look good and still sturdy?
I was thinking of a plexi level, but I'm not sure if I will be able to cut wholes out of it?
I also have like 8 control panels.  So I'm trying not to do anything super expensive.... Unless that is the only real solution.
fjl
  • Pixels Rule!
Re: Finishing control panels?
« Reply #1 on: May 12, 2008, 11:27:42 pm »
Plexi. I drilled a starter hole then used my router with a flush trim bit to cut holes to exact dimensions/sizes and locations to the CP. Worked liked a charm.
You can also try laminate.
