Author Topic: hantrex polo 25 drivin force prob  (Read 3642 times)
G1zm0
  • Last login:October 05, 2020, 06:57:58 am
  • cute by day, devil by night
« on: May 09, 2008, 05:41:22 am »
just took delivery of a drivin force game, when booted on the screen shows the rom check with lines going through diagonaly, the white is out of focus, i heard a noise like static so took back off and when powerd on and at bottom of anod cap you can see little blue spider like flashes going down about 1/2 inch does this a bit and stops but theres stil the noise of like when radio aint tuned in right, the neck tube light is a bit dull and not bright (unknowen if this is ment to be this way) and when its switched off you get a red dot in middle of screen for about 3 secs but was told this is normal, , the only colours i see are the rom check ones as it has a bad rom and wont skip this part, is this monitor savable or is it dangerous, thanx
grantspain
Re: hantrex polo 25 drivin force prob
« Reply #1 on: May 09, 2008, 01:01:39 pm »
you need to allow the cab to dry out,you have condensation around the anode cap-if you want you can remove the anode cap and clean off all the dust and crap and make sure its nice and dry
it will probably work fine once dry
G1zm0
« Reply #2 on: May 10, 2008, 03:44:15 am »
as always i can rely on you for sound advice, as was told it was off for about 4 month, prob the rom chips need dryed out to s it fails rom check, i have a turbo out run cab and at bottom there is a big cap 3 transformers of 1 is for monitor and one for jamma, but the other one aludes me, there is a board at bottom to, i take this as being the sound board? wonder if it can hook up to anything else oter than this game
grantspain
« Reply #3 on: May 10, 2008, 12:57:18 pm »
the monitor needs the drying out as i bet it was stored in a garage or shed,you would need to leave this in a warm dry environment for 48 hrs
you will also probably find a lot of corrosion around the eprom legs/sockets which is more than likely giving the rom failure-you could try cleaning the board
i would say that cab is dedicated to that game but there is nothing to stop you rewiring the cab for any system
G1zm0
« Reply #4 on: May 11, 2008, 02:19:26 am »
i took board out, theres no corrosion on any legs there all smt, and the error is 31s/s bad rom 66df, but i cant find the location on the board,the monitor i dryed out with hairdryer and paper towels, no sparking at cap now, but the screen with the driving force game in stil got lines through it and kinna dull white you can only make out from standing infront of it, i wil try get few pics
Lutus
  • Last login:August 23, 2012, 10:58:10 am
  • "I love my Power Glove. It's so BAD!"
« Reply #5 on: May 11, 2008, 04:55:00 pm »
Have you adjusted any of the controls on the flyback?
Or any monitor controls at all for that matter?
www.justin.tv/lutus8
www.encoreinstruction.com <-- for my fellow musicians
G1zm0
« Reply #6 on: May 12, 2008, 03:51:59 am »
not yet , unknowen what controlls to adjust, and might wait till i get something that will show a image on it, also my turbo outrun monitor that is a wg the gfx has like ghosting effects making it look like crap, is this a chip or moitor issue, dam that t outrun cab has a big ass power board at bottom of cab, unknowen if this is a power distribution board as all transformers are separate
grantspain
« Reply #7 on: May 12, 2008, 08:05:40 am »
ghosting could be down to badly adjusted colours/contrast or capacitor issues
G1zm0
« Reply #8 on: May 13, 2008, 06:48:11 am »
i have left the unit on for a few days and noticed as  you will see in pics the metal tray overing the components is rusted and the wire winding on the yoke part is not shiny as u see in pictures , the screen is still same if you look at picture you will see the lines i am on about ( not the thick ones as thats the camera) on board it has test i put this to on but still blue screen , as you can see in another picture the rom check txt is dull white, what do you recoment i try, its polo 25, also i include a turbo outrun picture,
grantspain
« Reply #9 on: May 13, 2008, 01:59:20 pm »
well either your screen volts is way high or ic1 on the neck card is dead,
first adjust the contrast and screen volts,the screen volts is on the flyback tranformer and the contrast is on the remote board
G1zm0
« Reply #10 on: May 14, 2008, 08:07:19 am »
the contrast was on full, so i put the brigtness right up and the picture was still a bit weak so i adjusted the "screen" on the flyback down a tad.
 but still same, so i increased it a bit and the picture is brighter (there was some white glue ontop of the adjuster so i took it off)
the horizontal lines are still there, and the screen takes about 4-6 secs to come on, amd some crackles can be heard and hissing when 1st put on
G1zm0
« Reply #11 on: May 15, 2008, 05:44:43 am »
today i thought i would inject a video signal to this cab from my turbo out run cab.
so i made up a lead that would reach over to the r force machine, red-red . gnd to gnd ect, when i booted up the machines the picture is there but it shows 2 flickering jumping turbo out run screens with very little colour
the reds are like yellows, i was going to try using the 2 syncs together but both machines are horizontals, lots of the components are rusty, maby it needs skiped and a tv put in or a cap kit? any suggestions
G1zm0
« Reply #12 on: May 15, 2008, 06:24:42 am »
would a cap kit help the monitor or would it not make any dif. i found a place in uk. i think this is for the 25"
it says following
Cap kit for MTC9000/9110. Contents, 19 of the most vulnerable capacitors. (C53 not included). All 105C. £5.56 (HAN007)
470MFD 200V 105C Capacitor. (C53 on MTC9000) £5.95 (HAN010)
i cant see if mine is a mtc9000 or what it is, doesnt say in manual, on monitor or in parts list, i cant even find c53 on diagram
grantspain
« Reply #13 on: May 15, 2008, 06:48:09 am »
you have a polo1 chassis,i know someone who can repair this chassis at a good price for you
G1zm0
« Reply #14 on: May 16, 2008, 10:42:20 am »
some latest pics of prob, picture 20 is the lines i get on monitor (no signal is connected)
picture 28 is green due to camera i think
pictures 26 and 27 is outrun runnig from another cab but signal is connected to this monitor.
the picture shows 2 screens and flickers with lines and and colours not correct(board works ok)
Lutus
« Reply #15 on: May 16, 2008, 11:08:16 am »
You probably put a gameboard (the second one, with the double image) that requires a different wiring for the Hsync and Vsync.
With no video input, adjust your flyback screen volts DOWN until the monitor looks almost black.
You should definently do a cap kit on this chassis and that may answer most of your questions.
G1zm0
« Reply #16 on: May 16, 2008, 04:51:37 pm »
tryed  adjusting the flyback anticlockwise with no video input, the screen is still blue, tryed turning that down still blue,
with the voltage down, when i insert original signal its dark (txt) till i turn it uo then its nice white and red is red, but still got the horizontal lines.
   when i put it on test mode it does nothing but add vertical lines and i get short bursts of like static random lines ( like a c64 loading). and screen gives faint pulse flashes.
  there is a high pitched noise from back of monitor, from the neck of it (i dont know if its ment to do this)
grantspain
« Reply #17 on: May 16, 2008, 07:32:14 pm »
looking at your pics it is clear you have more than one problem with this monitor.
i know from just looking that this monitor has been stored in a shed or garage and is therefore damp.
you can also see that the vertical hold/position pot is knackered and the blue drive transistor is shagged
to fix this chassis you need to be a reasonable tech,you need to change T6(bf859),RV403(1K pot),RV401(4k7 pot)
you need to clean the anode cap and area aroung the anode as well,also i would replace r36(270r) and c14(4r7 250v)
bet that sorts your problem
G1zm0
« Reply #18 on: May 17, 2008, 05:07:14 pm »
so thats how its blue, how is it when i put the original game pcb on it doesnt go out of sync? ive found all locations on a schematic i got with the monitor, will order parts later, so this will fix all probs? cool.
 thought id need to dump monitor, i will keep u posted how i get on, now to go to cpc.com
« Last Edit: May 17, 2008, 05:25:51 pm by G1zm0 »
G1zm0
« Reply #19 on: May 19, 2008, 06:27:23 am »
found all locations on the video amplifier, so going to maplin now to see if i can get them.
the only one i might ahve trouble with is t6, will let u know how i go,
also the anoid cap needs good clean the sucker has white deposits and one terminal is kinna blue tipped prob with heat.
and down where flyback is theres like bits of metal or silver stuff there prob of the cage, will give board good brush  to and hopefully it will work
grantspain
« Reply #20 on: May 19, 2008, 07:38:10 am »
bits of metal stuff sounds like an exploded capacitor to me
