Author Topic: mame configuaration for pedals  (Read 1148 times)
scuzzie
  • Last login:November 28, 2008, 06:54:23 pm
« on: May 04, 2008, 10:47:48 pm »
I'm wiring up a set of cruisin USA pedals to run on MAME through an Ultimark A-Pac.  In the MAME game of Cruisin USA under Input (this game), I get the following for Pedal 1 analogue : 'Joy 1 X Rotation 'Joy 1 Z Rotation Joy 1 Y Rotation'  . . . much the same for pedal 2.  Whaty I want is pedal 1 - X axis, Pedal 2 - Y Axis and steering to be X Rotation.  Can anyone help me on this.  Thanks , . . . .
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re: mame configuaration for pedals
« Reply #1 on: May 06, 2008, 06:32:43 pm »
In the windows game controls control panel, where are the pedals when pressed and not press?  (example: brake is all the way down when not pressed and all the way up when pressed.)  Are are nothing wired to Zr & Yr axes?  Are you sure the pedals are the X and Y axes, and the wheel the Xr axis?  You get that weird setup after you try to remap, or does it look that way when you open the UI input menu?
If it's just a remapping issue in mame, you can hand edit the cfg file as a work around.  Exit mame, open the cfg file in notepad, and look for the pedals "standard" input "ports".  Change them to the correct axis and save.  Restart mame and test if it works correctly.
Robin
Knowledge is Power
