Author Topic: Problem with K7000 and a white screen  (Read 2743 times)
smac666
  • Last login:September 25, 2016, 12:40:02 am
« on: May 04, 2008, 09:49:06 am »
Hi,
I have a problem with the monitor in my defender cabinet.
I had been restoring the cabinet and had the game set up on a bench.
Monitor and games worked fine, I blew everthing down with air and put it back in the cab.
Now when I turn the game on all I get is a white screen, see attached photo.
I think its a senith chassis as it have 2 red anode leads.
If you disconnect all the inputs and power the monitor on then it fires up like normal with a blank screen.
Connect the wires and its all white, I tried a different monitor and the game worked fine.
I pulled out the chassis and reflowed the solder on the back side.
Still get a white screen. anyone got any ideas.
Regards
Steve
grantspain
  • Last login:Yesterday at 07:14:10 pm
Re: Problem with K7000 and a white screen
« Reply #1 on: May 04, 2008, 10:37:24 am »
sounds like something is unplugged on the video side of the chassis,either that or you have some kind of blanking problem
Ken Layton
  • Guru
  • Technician
« Reply #2 on: May 04, 2008, 11:28:19 am »
Did you accidently unplug/plug something in wrong?
Bump the "SCREEN" control on the flyback?
smac666
« Reply #3 on: May 07, 2008, 12:41:27 pm »
Hi,
Sorry for the late reply but work has been interfrening with my social life.
I tried to wiggling the focus and screen controls but got nothing new.
I rechecked all the connectons and can't see anything obvious that is wrong.
I have a spare board from a single anode Lead chassis (none zenith I think) K7000 and changed the neck board and chassis out and the monitor came up fine, So its definetely the circuit board that has a problem.
So what the most likely cuplrit?
Reagrds
Steve
Ken Layton
  • Guru
  • Technician
« Reply #4 on: May 07, 2008, 12:58:41 pm »
Did you accidently break/crack the brightness/contrast controls? Any other compenents accidently get their leads pushed over and touching an adjacent component's leads?
Did a nut, washer, or bolt come loose from somewhere and land on the ciruit board or maybe even roll UNDER the circuit board?
smac666
« Reply #5 on: May 07, 2008, 06:55:35 pm »
Well it has a seperate little daughter board with six pots on it.
One of those was damaged (I think the bottom left with the wires facing up), but I replaced it straight away with an identical one.
I never thought of that, but I will double check tonight that it is the correct rating.
I'm sure it is, but you never know, I might have misread it.
Thanks for all your help so far.
Regards
Steve
SirPeale
  • Green Mountain Man
« Reply #6 on: May 07, 2008, 09:18:23 pm »
Make *absolutely* sure you replace it with the correct rating, you don't want to damage your monitor.
smac666
« Reply #7 on: May 08, 2008, 08:35:10 am »
I didn;t have a lot of time and I checked it last night.
It was the vertical hold pot and it had been replaced with the correct size.
Guess I'll keep trying
Steve
