Author Topic: Single Button ON/OFF, Damage to PC?  (Read 1108 times)
babydickonboard
  • Last login:May 22, 2008, 08:28:56 pm
  • {/....KILL YOUR TELIVISION....\}
« on: May 04, 2008, 12:21:47 am »
I was just wondering what you guys think about "hard" shutdowns of a pc while in mame. (i.e. pulling the powerplug) I want to wire everything in my cab up to a single switch, and have the pc set to restore power after failure. I'm a bit worried about the computer on shut down tho. I'm sure that MAME isn't writing much at the time, but im worried about my HDD crashing.
I was looking through the forum, and someone was talking about decreasing winXP HDD cache write  thru device manager->disk drive->property's->policy. I was just wondering if anyones had any troubles with there PCs doing this, or if there are some other things you've done to help prevent damage.
-thanks
mhermann
  • Last login:October 04, 2019, 07:10:08 pm
  • We ain't found.........
Re: Single Button ON/OFF, Damage to PC?
« Reply #1 on: May 04, 2008, 12:54:58 am »
This isn't a concrete answer but I was always under the assumption that as long as the hard drive was not being written to you were ok. So with Mame I guess the only writing would be to a high score file. SO as long as you exit out to your front end I would think you would be fine.
« Last Edit: May 04, 2008, 01:48:21 am by mhermann »
paigeoliver
  • Awesome face!
« Reply #2 on: May 04, 2008, 01:45:24 am »
I have had Mame machines that have endured hard power-offs for years and years with no errors. A mame cabinet isn't writing a thing other than high score files.
babydickonboard
« Reply #3 on: May 04, 2008, 01:54:28 am »
thats what I was thinking too, I just wanted to be sure cause I want everything hooked up to one master switch thats tied to my powerstrip.  I was think that I was going to have to get/make a smartstrip, but this should work.  Thanks for the input!
