Author Topic: Exisiting Cabinet speaker  (Read 1941 times)
wrighty
  • Last login:May 22, 2008, 06:48:32 pm
« on: April 26, 2008, 10:04:07 am »
For my mame project I am about to start installing the audio side. My golden tee machine already has speakers in it How can I use these with my PC? I have read the build your own arcade machine book but it seems to be orientated around a build from scratch rather than having an existing cab!
Cheers!
DrumAnBass
  • Last login:July 10, 2024, 10:36:54 pm
  • "I love this computer magic!" - Viv Savage
Re: Exisiting Cabinet speaker
« Reply #1 on: April 28, 2008, 07:30:47 pm »
Generally your PC will have a "line out" which is an un-amplified audio signal. So you need to amplify the signal to deliver some decent volume to drive the existing speakers.
This can be done a number of different ways.
Here are a few options:
1) Hack a set of amplified computer speakers. The wires that would normally attach to the satellite speakers would get wired into the existing cabinet speakers.
2) Use a dedicated home audio amplifier. This could be an old (or new) stereo receiver or a small dedicated amp (such as the one kevinp pointed out here: http://forum.arcadecontrols.com/index.php?topic=79015.0)
3) Car stereo amp. These generally run on 12v which can be tapped from your computer's power supply. They are readily available and can be very inexpensive.
Good luck!
"Some drink from the fountain of knowledge; I only gargle."
