Author Topic: Kortek KTM-F20, any good ?  (Read 2735 times)
Level42
« on: April 25, 2008, 01:46:25 pm »
Just picked up a Kortek KTM-F20. It has a Samsung tube. How are these ?
Paid 40 euro's, including an isolation transformer (also 230 V to 110 V) and a switcher PS mounted together, plus  a circular shaped frame that I guess makes it easy to rotate this one from horizontal to vertical....
The Kortek looks pretty flexible with switches for sync- selection etc. Nice colored pots for RGB etc.
grantspain
  • Last login:Yesterday at 01:42:17 pm
Re: Kortek KTM-F20, any good ?
« Reply #1 on: April 25, 2008, 02:18:45 pm »
keep an eye on the caps with these,you will find a few mounted right next to some pretty powerful heat sources
a pretty flexible chassis,lots of good adjustments
Level42
« Reply #2 on: April 25, 2008, 05:40:20 pm »
Thanks for the tip !
I'll check them out. Yeah, looks like a pretty decent set-up. I am planning to use it in my Puckman with a 48in1....
The frame is really weird. It's a metal circle which apparantly should fall into an angled frame. The degauss wire is also with it (has to be able to turn too I guess. I can't figure out how it should turn though. I'll make a picture tomorrow.
