Author Topic: spacific grounding question  (Read 1354 times)
skirge66
  • Last login:June 03, 2003, 06:25:58 am
  • the stupid will normally punish themselves
« on: May 29, 2003, 05:54:42 am »
ok, I am using a Hagstrom KE72 for my encoder running to a pair of IOX36 breakout boards (also from hagstrom). so here is the question:
each breakout board has 4 ground screws one on each of the 4 blocks (I am assuming that these 4 are all going to a common ground) . now with 2 breakout boards will I need to connect the ground for both these boards together? Also when it comes to "daisy chaining" the grounds will it matter which ground I connect to? From what I can tell it appears that the KE72 has 8 ground pins on it.
skirge66
Diplomacy is the art of saying "nice doggy" until you find a bigger rock to throw
