Author Topic: Top Gunner sprite problem  (Read 1301 times)
covey
  • Last login:February 14, 2009, 07:50:00 pm
« on: April 25, 2008, 08:59:55 am »
Looking for a little help. Picked up a Konami Top Gunner board. Everything is fine until you try to play the game. The jeep you drive is nowhere to be found. You can tell your moving the jeep, the screen scrolls with you move the joystick. Other things on the screen don't look 100% but are visible. +5 voltage is right on. Pulled all the ROM's and cleaned connections, reseated. No change. Any ideas? Thanks
lanman31337
  • Last login:January 10, 2024, 10:36:50 am
  • set to ludacris speed!
Re: Top Gunner sprite problem
« Reply #1 on: April 25, 2008, 09:34:52 am »
Sounds like a possible bad video rom.
covey
« Reply #2 on: April 25, 2008, 10:25:56 am »
Any idea which one to look at? If I can narrow it down, i'll tyr to pick one up. Thanks
Lilwolf
  • Last login:Yesterday at 09:58:06 am
« Reply #3 on: April 25, 2008, 01:11:14 pm »
take a look at the mame driver.  Sometimes they document them in there.
