Author Topic: U360 Shift Function PROBLEM  (Read 1804 times)
koolmoecraig
    • My Intervention
« on: April 23, 2008, 10:23:52 pm »
I have my U360 updated to the latest firmware(2.4) which is supposed to have shift functionality.  I am having a weird problem.
Button #8(Violet Wire) on the U360 button harness is supposed to trigger shift mode when held down.
In Windows while doing a button test, the button I have hooked up to the #8 Violet wire shows up as it should as button #8.
When I am in Mame trying to configure buttons, that same button is showing up as Button #7. Therefore I obviously cannot use the shift function.
Anyone have any idea what would cause this???????
Ginsu Victim
  • Comanche, OK -- USA
Re: U360 Shift Function PROBLEM
« Reply #1 on: April 24, 2008, 08:17:02 am »
Test the other wires by touching them to the ground wire and see which one shows up as button 8. It could just be a wiring error on the manufacturer's part.
destructor
« Reply #2 on: April 25, 2008, 02:30:51 am »
In Windows bottons are numbered 1-8, in MAME 0-7.
Ginsu Victim
« Reply #3 on: April 25, 2008, 08:23:11 am »
^That is true.
koolmoecraig
    • My Intervention
« Reply #4 on: April 25, 2008, 12:24:18 pm »
Good call.
Thanks.
