Author Topic: Too good to pass up  (Read 4295 times)
Paul Olson
    • Paul's Arcade
Too good to pass up
« on: April 22, 2008, 07:39:16 pm »
I was content with my MAME cab with a modular cp, mostly because I don't have room for anything else. Well, I now need to make room. I saw this Ridge Racer on CL for $200 and I couldn't resist. It is currently sitting in the garage, and I think it is going to have to stay there - this thing is huge  :)
Ridge Racer is definitely showing its age (1993), but it is fun for the price.
Ginsu Victim
  • Comanche, OK -- USA
Re: Too good to pass up
« Reply #1 on: April 22, 2008, 10:17:22 pm »
Working with no problems?
Good deal either way.
Jdurg
« Reply #2 on: April 22, 2008, 11:32:13 pm »
Very nice.  God it's sad to think of that game as a "classic", but it's 15 years old now.  Wow that's scary just thinking about it!
Donkey Kong High Scores:
1): 49,500
2): 35,600
3): 30,100
4): 29,400
5): 28,200
Paul Olson
    • Paul's Arcade
« Reply #3 on: April 23, 2008, 09:18:49 am »
The clutch and the shifter are not working at the moment. The guy I bought it from thinks it is a menu option, but I think they may be unplugged. I'll check it this weekend.Otherwise, everything works fine. This game was in his house, so it was played regularly, and it plays great.
jdburg - I hear ya. I was already 22 when this came out - damn I feel old :)
Paul Olson
    • Paul's Arcade
« Reply #4 on: April 23, 2008, 08:15:31 pm »
The steering wheel was loose, so I tore the cp apart to try to tighten it up the mount for the force feedback springs had ripped a hole in the mounting bracket of the wheel. The other mount had broken through before, and someone badly welded a patch on it. It is amazing how operators patch things together over the years to keep these things earning. I had a happs wheel similar to this one, so I used the mounting plate to replace the one from the game. Now the wheel is great, and I only spent $20 for the wheel on ebay last year, so it was a cheap fix. I still have not figured out the shifter and the clutch. I need to find a wiring diagram for this game, it is hard to trace the wires in the cabinet, and I would like to get away with leaving them tied up nice inside there.  :)
After tearing apart the CP, I now realize that I have a lot of cleaning ahead of me - this thing is pretty nasty under a nice looking exterior. I found a bunch of tokens hiding in any nook and cranny they could get into. Looks like this game has been all over California.
I will be spending some time in the monitor forum this weekend. The image looks like this:
__________
I can't figure out how to adjust it. If anyone knows how, please let me know.
Paul
____________
SavannahLion
« Reply #5 on: April 24, 2008, 12:37:40 am »
Let me guess? Reno?
I see a few pretty good deals coming out of Reno, but the drive would necessitate a weekend haul and drop. Seems most listers aren't interested in weekend runs. Oh well. :dunno
Paul Olson
    • Paul's Arcade
« Reply #6 on: April 24, 2008, 01:22:27 am »
Yep, it's Reno. A couple of months ago I missed a Donkey Kong, Defender, and Pole Position for $250 each. I look at CL many times a day now.  :)
I made some more progress on the cab tonight, easy fixes. A loose plug on the PCB was causing the clutch and shifter to not work. After I got that working, one of the switches wouldn't register. A loose wire at the same harness, I just shoved it in for now. I'll have to figure out how to crimp it in there later.
I still need to fix the pincushion problem, and make a couple of brackets to hold the two cab pieces together. The seat doesn't lock into position, so I will have to fix that too. After that is done, it will be time for a lot of cleaning.
Now that everything is, or is close, to working, that $200 is seeming like an even better deal.
TheDriver
  • Last login:December 21, 2008, 04:08:37 pm
« Reply #7 on: April 24, 2008, 07:47:31 am »
20 min's down the road from me are these:
Shorten Those Links, Dammit!
If I had the space I would get them but they are just too big, and apart from anything else my girlfriend has already said no chance!  :censored:
I have always liked RR myself pcolson & $200 was a steal! :)
Regards.
« Last Edit: May 01, 2008, 12:38:30 pm by Peale »
Angry_Radish
  • Last login:October 24, 2020, 06:36:17 pm
« Reply #8 on: April 24, 2008, 09:41:48 am »
Congrats on the Ridge Racer!
Mine doesn't have the topper, I'm jealous now  ;D
I have the manual for that type (the ones online are different styles), I'll see if I can bring it into work and scan it into PDF format for you.
Paul Olson
    • Paul's Arcade
« Reply #9 on: April 24, 2008, 07:54:00 pm »
TheDriver - buy them anyway! You will find somewhere to put them, your girlfriend will never notice.  :laugh2:
I drive a Scion xA, and this game is not too much smaller than my car!!! It is huge.
Angry_Radish - I would really appreciate that. The ones online are completely useless for this version. The guy I bought it from said this cabinet was a prototype, do you have any idea how many were made? If I ever see a topper for sale, I'll let you know.  :)
