Author Topic: Help with a 33" tube ID  (Read 1908 times)
Arm123
  • Last login:March 03, 2025, 11:26:20 am
« on: April 20, 2008, 01:09:34 pm »
I’m trying to find the heater value for this tube, so i can test / rejuv it.
Anyone recognize it ?
Arm123
Re: Help with a 33" tube ID
« Reply #1 on: April 20, 2008, 01:30:28 pm »
The chassis that was on it was Kortek KT-3301
I cant seem to find any combination of those numbers, in my bk setup chart (August 1999 Edition).  Anyone have an updated copy of the setup chart ?
« Last Edit: April 20, 2008, 08:18:15 pm by Arm123 »
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #2 on: April 20, 2008, 10:54:06 pm »
don't have a number for ya , but try pins 9,10 for filaments
and the rest may be
5  g1
6  green cathode
7  g2
8   red cathode
9   fil
10 fil
11 blue cathode
qrz
Arm123
« Reply #3 on: April 21, 2008, 11:15:31 am »
thanks for the reply qrz   ;D
Im just worried about getting the heater and G1 voltages wrong.  I was thinking of just using the most common values H 6.3v , G1 50v  What kind of damage would that do ?
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
« Reply #4 on: April 22, 2008, 07:04:34 pm »
Try searching for the same number but start it with an A.80EEF..... The B in front indicates it is a B grade tube. A lot of my competition do this. one of the biggest reason I get beat out on pricing.
Based on the "red" coating on the back of the tube instead of Grey, likely made in the North America...nope in fact positive it is a Phillips "B" Grade tube, likely Totoku yoke.
Hope this helps and good luck.
Rick Nieman
www.niemandisplays.com
Always happy to help.., for the best in displays
Rick Nieman
Rick@Niemandisplays.com
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
Arm123
« Reply #5 on: April 23, 2008, 12:22:37 pm »
Its definetly manufactured in the US.
Thanks very much for the info Rick   ;)
[edit]
did some searching, only results i found were making reference to a Phillips tube.  So your right.
[/edit]
« Last Edit: April 23, 2008, 12:57:11 pm by Arm123 »
Arm123
« Reply #6 on: April 23, 2008, 06:56:39 pm »
Turns out that i tried to test the tube and the R, B guns were in the bad and the G gun was dead.  I tried to rejuvenate the guns and the R + B guns moved up a bit but the G moved a hair but was still close to dead.  So this tube is dead !
So sad.
See here for more details...
http://forum.arcadecontrols.com/index.php?topic=72736
« Last Edit: April 23, 2008, 11:21:23 pm by Arm123 »
