Author Topic: Groovy Game Gear Rotary Help  (Read 1453 times)
campbelldave
  • Last login:March 11, 2016, 07:48:48 am
« on: April 17, 2008, 08:47:57 pm »
Hello All,
I am having some problems getting the Groovy Game Gear Rotary  interface to work.  I was hoping someone else on the board had used it before.  Sorry if this is a dumb question - I did read the instructions and put some time into it before asking:
In order to wire the rotary joysticks, do I connect wires 1,4,7,10 to K, 2,5,8,11 to M and 3,6,9,12 to O? Does the ground wire on my Happ rotary joystick just go to the ground on the board or does it need to be connected to each input?  Also, do I need to do anything special once inside of MAME on the Position analog settings to make sure MAME knows a rotary joystick is attached?  Does it use characters X and Z for left and right?
Any help would be greatly appreciated.  Thanks
wbassett
  • Last login:October 05, 2024, 02:18:42 am
Re: Groovy Game Gear Rotary Help
« Reply #1 on: April 17, 2008, 10:18:33 pm »
If nobody here answers up with help (which would be doubtful), try calling Groovy Gear and ask them, I'm sure they can give you some guidance. :)
When in doubt... the phone is my best friend!
RandyT
  • Last login:June 24, 2026, 02:15:54 pm
    • GroovyGameGear.com
« Reply #2 on: April 18, 2008, 02:58:38 am »
I replied to this in email.  Did it not make it to you?
I'll try sending it again.
RandyT
