Author Topic: vga to rgb its Soft-15kHz all i need?  (Read 2482 times)
Denverlatino
  • ---Buyer Beware - transactions with this user are in dispute--- ... Banned ...
  • Last login:May 13, 2009, 02:55:24 pm
« on: April 15, 2008, 09:39:02 pm »
Im planing into making this old pc into a mame dedicated machine for pacman games only, i have the cab with everything on and just wondering if i make a vga to rgb cable and use Soft-15kHz , its probably all i need, the video card integrated to the pc its a dell gx1 with p3 500 mhz and and ati agp 2 integrated video card, could it be posibble that no special hardware i will need?  :cheers:
[transactions in dispute -- see http://forum.arcadecontrols.com/index.php?topic=77030.0]
... Banned ...
Re: vga to rgb its Soft-15kHz all i need?
« Reply #1 on: April 16, 2008, 05:51:00 am »
Assuming Soft 15khz is compatible with your video hardware then you should be OK.
However I don't know if integrated graphics works or not...some can be picky with custom modes from what I can gather.  I think there is a list of supported video cards in the Soft 15khz part of the BYOAC wiki.
Denverlatino
« Reply #2 on: April 17, 2008, 07:07:46 pm »
Mine its not suported, but i think i can get a cheap one, by the way, what FE can i use for 15 khz monitors under windows xp_?
... Banned ...
« Reply #3 on: April 18, 2008, 04:31:53 am »
I am pretty sure most of the popular FE's which allow you to set screen resolution should work.
I use Mamewah (of course), but with an ArcadeVGA. I have not used Soft-15khz but I believe it uses custom video modes so in theory should work just the same.
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
« Reply #4 on: April 18, 2008, 05:35:42 am »
Warning , if you use a simple cable.
You have to be aware that when you PC is booting it will ouput a 31khz signal until the driver Soft15khz is loaded.  During this time you screen will take 31khz instead of 15kz and could damage it  (on more or less long term , it really depend of your screen).
However if you use a JPAC for instance , the JPAC protect you screen while the output is superior to 15khz bu dividing the frequency by 2 . But if you don't have this hardware or similar , it can be dangerous.
Concerning Front end ,  I have users of mine (AtomicFE)  that use it with Soft15khz and it works. As said Minwah almost all popular front end should work with it, that's not a issue.
Denverlatino
« Reply #5 on: April 18, 2008, 11:49:24 am »
Most screens i see here that use this kind of japanese jamma pc too jamma connection dont get damage, and they run pretty cheap here, i might try one of those with 15khz software to try not to avoid my screen, thanks for the advise.  :cheers:
... Banned ...
youki
    • Atomic Front End
« Reply #6 on: April 18, 2008, 04:38:39 pm »
Yes , most of the time it works... but for how long..
If the screen is a little bit old , it could be damaged at the first try.  One of my friend had this problem and he was using a PC2JAMMA device too .  In fact he wasn't using Soft15khz , but ARCMON.SYS under dos , that does the some thing for DOS.
The problem was that at boot , the PC init screen (BIOS info etc...) was not at 15khz until the driver was loaded... and the screen didn't liked at all..
But i also know guys that don't have problems for now. I think it really depend of your screen  and if your are lucky or not!. ;)
Denverlatino
« Reply #7 on: April 18, 2008, 09:19:51 pm »
Ill post results too see if i didnt got screw.  :cheers:
... Banned ...
