Author Topic: k4900, no vertical deflection  (Read 3489 times)
Malacus
  • Last login:April 17, 2010, 12:42:16 am
  • DANCE!
« on: April 15, 2008, 06:01:06 pm »
Heres my story, short and sweet, I saw a k4900 (its a 4906 to be exact) on craigslist, ad said it was working, i went to pick it up, he tested it there, saw his pole position playing on the screen, though the picture was very short, only took the center of the screen, he said "it just needs adjusted" and not knowing much about anything monitor related, I went ahead and got it (it was only 35$)
So, as soon as I get it all hooked up, I power it on, and...
single blue line across the screen...
Following the flowcharts i see that this is a vertical deflection issue.
So here are my questions, where do i get the parts to fix this? would the necessary parts come in a cap kit? Would I be able to head over to http://www.partsexpress.com (they're local to me) and pick up what I need? How do i know if I need q302, q303 or ic 301, i dont know how to check them... i have a multi-meter, but the only thing i know how to do with it is to check if something has a short  :dunno
Thanks,
mal
~Classic Gaming Since 1983~
grantspain
  • Last login:Today at 01:17:02 am
Re: k4900, no vertical deflection
« Reply #1 on: April 15, 2008, 06:21:59 pm »
most likely you have a bad solder joint or a bad circuit track,it is worth checking this first
Malacus
  • DANCE!
« Reply #2 on: April 15, 2008, 06:27:14 pm »
i resoldered the only thing that looked bad to me, and it didnt seem to do anything...  :dunno
-mal
Ken Layton
  • Guru
  • Technician
« Reply #3 on: April 15, 2008, 06:37:15 pm »
Recap it and also check the giant white resistors near the main filter capacitor for a bad solder joint or if the resistor has gone open circuit.
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #4 on: April 16, 2008, 11:19:49 pm »
q203 and q303  (2sc2073) will likely need to be resoldered .
check/replace c313  sweep return, c311 supply decoupling,c310,c308,c373. also check r307 220k.
check c303 and c301 near ic301 (ha11423)
should be an easy fix
qrz
Malacus
  • DANCE!
« Reply #5 on: April 18, 2008, 11:49:16 am »
Well, I looked over the caps, and c313 was visually really old and dirty.
So, I replaced it first. The cap that was there was a 100uf 160v, Lizard Lick Amusements has you replace it with a 100uf 250v, but the k4906 manual says to replace it with a 47uf 160v... So I figured the manual knows best and went with the 47uf 160v, plugged everything back up (the rest of the caps look very recent, and I can replace them when Ive got more time.) and there it was, I could finally see my S.Street Fighter: TNC
-mal
Lutus
  • Last login:August 23, 2012, 10:58:10 am
  • "I love my Power Glove. It's so BAD!"
« Reply #6 on: April 18, 2008, 12:05:04 pm »
Would probably go ahead and recap the whole thing when you get the chance.  (unless you already have, can't tell from the post)
Otherwise,  congrats!   :cheers:
www.justin.tv/lutus8
www.encoreinstruction.com <-- for my fellow musicians
