Author Topic: best tube to use in a GO7 tube swap?  (Read 2931 times)
The_Tyler_Black
  • Last login:March 19, 2010, 03:01:13 pm
  • Mario on shrooms!
« on: April 15, 2008, 02:37:57 am »
I have a burned out GO7 in a ladybug machine but was wondering if anyone here had "tube swapped" one?
If so what monitor (tube) did you use?
Im thinking about going to goodwill and getting an old tv but was wondering if there was a certain brand that would be easier to do!
Appreciate it!
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: best tube to use in a GO7 tube swap?
« Reply #1 on: April 15, 2008, 05:44:13 pm »
what is the original crt number ?
ideally , staying with the same number tube will reduce difficulties.
many crt's have the same pin out and similar specs.
so, it's not that difficult . however, your skill/knowledge base may influence the outcome .
qrz
The_Tyler_Black
  • Mario on shrooms!
« Reply #2 on: April 18, 2008, 03:03:33 pm »
Thanks qrz, but i have decided to take another approach on the cab. Mameing it for my father (tetris and mario fan) so im just gunna drop a PC in it and a monitor!
Lutus
  • Last login:August 23, 2012, 10:58:10 am
  • "I love my Power Glove. It's so BAD!"
« Reply #3 on: April 18, 2008, 03:45:28 pm »
I'll take that G07 chassis back from you.
And you left the Keywiz instruction sheet at my house.  DOH!
www.justin.tv/lutus8
www.encoreinstruction.com <-- for my fellow musicians
