Author Topic: B/W monitor, replace with a B/W TV ?  (Read 1552 times)
Level42
« on: April 09, 2008, 04:36:40 pm »
Since I've replaced two color arcade monitors with TV's I was wondering how hard it would be to use an old B/W TV-set as a monitor for an old B/W game.
Would it be easy f.i. to replace only the CRT (From the TV to the monitor chassis) ? Do I have to think of yoke impedance, CRT angles ?
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
Re: B/W monitor, replace with a B/W TV ?
« Reply #1 on: April 09, 2008, 04:57:19 pm »
A TV has a tuner an intermediate Frequency section (IF) in some case can be done but not easy.
It is probably easier to replace with a color monitor.... tie the red, green and blue signal inputs together and connect the signal wire from the B/W game.
Hope this helps.
Rick@Niemandisplays.com
Always happy to help.., for the best in displays
Rick Nieman
www.niemandisplays.com
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
Level42
« Reply #2 on: April 09, 2008, 06:55:52 pm »
Thanks Rick,
Yeah I'm aware about the tuner. I remember that I used to have a portable B/W tv (only thing I could afford) for my Atari 600XL and some friend hacked in a video signal input to bypass the tuner.
And the using a color CRT......it's not the same thing...
A real B/W CRT has a higher resolution, and the phospor "color" is always a lot different from a color CRT running a B/W signal. Also think about convergence....Yes I am that anal about it sorry :D
Rickn
« Reply #3 on: April 09, 2008, 08:22:00 pm »
Been a while since I tried this but generally as all 3 colors rae on- convergence should have no play. Try it I don't think resolution will be an issue either as the color tube will have as approvx DPI of about  .8 to .9 mm
Rick Nieman
519-621-1722
