Author Topic: visible screws?  (Read 1633 times)
Stormrider
  • Last login:September 28, 2014, 11:01:54 am
visible screws?
« on: April 09, 2008, 09:35:59 am »
I'm installing my stick in a 16mm MDF panel. I don't know if I should use normal screws and fit the stick from beneath, so the screws are not visible on the top or use that kind of screws that use a nut, which would be visible, but I feel that the installation would be better and stronger. I could put them a little lower thatn the surface of the top, so that I don't notice anything when playing. Is there any othe solution? I don't plan on installing plexiglass or any other material covering the top and which could be used for hiding the screws.
Kajoq
  • Last login:June 14, 2024, 11:28:46 pm
Re: visible screws?
« Reply #1 on: April 09, 2008, 09:48:31 am »
Were you going to put art on the panel?
You could use Countersunk screws and then just put the art over the screws, which would be flush to the top
(+_+)
  • Let me splain.
  • Last login:July 27, 2012, 09:00:32 pm
  • For I am ]{eyser Soze
Re: visible screws?
« Reply #2 on: April 09, 2008, 10:15:49 am »
You can countersink the screws from the top as suggested by Kajoq except instead of screws use bolts (with a V shaped head) and a nut and lock washer. This way if it loosens you can always tighten from underneath.
This plan is so perfect, it's retarded. -- Peter Family Guy
Dazz
  • Last login:January 11, 2025, 07:43:39 am
  • HyperSpin Team
    • VPUniverse
Re: visible screws?
« Reply #3 on: April 09, 2008, 11:23:20 am »
How about use Tee Nuts on the top of the control panel and screw in from the bottom?
Stormrider
Re: visible screws?
« Reply #4 on: April 10, 2008, 02:47:14 am »
I will not use artwork. My panel will be painted. I didn't knew these tee nuts. Anyway, what's the difference? They are visible too... Or are these nuts installed from underneath?
« Last Edit: April 10, 2008, 02:49:42 am by Stormrider »
More Cowbell
  • That's just dumb!
Re: visible screws?
« Reply #5 on: April 10, 2008, 10:06:29 am »
Pretty much all of the cabs I have done with a wood control panel, I have screwed in from underneath to leave the top clean. I've never had an issue with anything working loose of breaking (3 years + now). If anything ever did break loose, drill your holes and do bolts from the top at that point.
I've got a fever...
