Author Topic: IPAC Shift Keys  (Read 1848 times)
bigmoe
  • Last login:July 16, 2004, 04:17:54 pm
  • I forgot my mantra!
IPAC Shift Keys
« on: May 27, 2003, 01:49:02 am »
I understand that the IPAC allows shift keys--using the button designated as "shift" (P1 start is the default shift key, if I recall properly), then pressing another, a second set of keypresses can be emulated.  This is used, for instance, to trigger "P" or "esc".
If I were to have a separate "Pause" button on my CP, could I wire that button to both of the appropriate inputs at the same time, thus *simulating* a shift-key sequence?  Or is the IPAC sharp enough to know it needs first the shiftkey then the selection?
It seems this would be nifty, so that I could avoid having to reprogram the IPAC or buy a second encoder if I wired up the first one...
bm
What was that again?
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re:IPAC Shift Keys
« Reply #1 on: May 27, 2003, 01:57:04 am »
Yes
Re programming is super easy.
You could just wire into one of your left over inputs on the ipac and assign that to pause in mame too.
