Author Topic: Monitor fit Q  (Read 1574 times)
crashdmj
  • Last login:August 26, 2003, 08:55:42 pm
  • Hulk smash!
    • Best webpage in the Universe!!
Monitor fit Q
« on: May 26, 2003, 05:53:46 pm »
Is it possible to fit a 27" D9200 in a 4 player D&D cab (contains an exsisting 25" monitor)? Also are the specs on the Happs website accurate (length, width etc) cause I could have sworn that someone posted that they werent.
Thank you
edit: One last thing...is it hard (im a newb) to use the existing monitor in the cab (not sure if it works...superauctions said it might be a bad power supply)? And is it hard to run windows with the existing cab...it's a 25" zenith monitor??
« Last Edit: May 26, 2003, 06:05:38 pm by crashdmj »
tom61
  • Last login:September 18, 2017, 12:46:56 am
Re:Monitor fit Q
« Reply #1 on: May 27, 2003, 12:00:28 am »
It used to be hard to get Windows on an arcade monitor. Now the ArcadeVGA from http://ultimarc.com makes it easy. A bit more expensive than a regular 64MB card, but way cheaper than the D9200.
crashdmj
  • Hulk smash!
Re:Monitor fit Q
« Reply #2 on: May 28, 2003, 02:23:50 am »
Anyone know about shoving a D9200 in a 25" cab, or if the dimensions of the D9200 are correct on Happ's site.
Derek
