Author Topic: Ms Pac monitor 'gaussed'???  (Read 6697 times)
newkillergenius
  • Last login:September 21, 2013, 03:48:35 pm
  • A mind is a terrible thing to taste.
    • The Mystery Revealed!
« on: March 31, 2008, 01:17:38 pm »
Hi all-
I saw this post elsewhere, though it's contents did not rectify my situation.
I just replaced the monitor in a Ms Pac-Man cocktail with a brand new vision pro from Happ.
It has gauss discoloration on the lower right & upper right corners.  I was told to power cycle the machine sevaral times and the degaussing coil would fix the problem.  It has not, and idea as to what I should try next?  Moving the machine all around the house just seems ridiculous, and doesnt ever get rid of the problem completely anyway.  The machine is 100% factory original, no aftermarket speakers or anything...HALP!
Don't ---steaming pile of meadow muffin--- where you eat, my friend.
SirPeale
  • Green Mountain Man
Re: Ms Pac monitor 'gaussed'???
« Reply #1 on: March 31, 2008, 01:29:13 pm »
You'll need a manual degauss wand.
newkillergenius
« Reply #2 on: March 31, 2008, 01:34:44 pm »
I was afraid of that.  May I ask why this happened?
grantspain
« Reply #3 on: March 31, 2008, 01:44:05 pm »
well hopefully either you degauss coil is not plugged in or your ptc component is dead
SirPeale
« Reply #4 on: March 31, 2008, 01:51:28 pm »
I'd sooner say the built in coil doesn't have enough oomph to correct the colors properly.  Especially since it's a new monitor and you've rotated it 90 degrees.
newkillergenius
« Reply #5 on: March 31, 2008, 02:18:07 pm »
This being brand new out of the carton, I would hope that isnt the case.....or do I????
Sheesh, even if I had a degauss wand, I dont know how to do the 'degauss dance'!
grantspain
« Reply #6 on: March 31, 2008, 02:48:54 pm »
manual degauss wands are very cheap to buy,all you do is hold it close to the tube then activate it whilst making circular actions steadily getting larger and further away from the tube
Shorter Link
« Last Edit: April 09, 2008, 11:28:27 pm by Peale »
newkillergenius
« Reply #7 on: March 31, 2008, 02:59:32 pm »
Is there a chance I can screw things up worse?  At this point I'll be 170$ into replacing the monitor in this thing.  :banghead:
whammoed
  • Last login:Yesterday at 10:23:48 pm
  • Crack don't smoke itself
    • NiceMite
« Reply #8 on: March 31, 2008, 03:03:24 pm »
Hi all-
How fast are you trying to turn it off and on?  I think it needs to stay off for a while before turning it back on for the degaus to function?  Nothing wrong with buying a degaus wand, but you may find if you are patient, after a few days of cycling the power off and on maybe once or twice a day, the problem will go away.  I found that to be the case when I moved my pac man cocktail recently.  It looked good again on the third day.  I own a wand but didn't bother using it.
« Last Edit: March 31, 2008, 03:20:52 pm by whammoed »
grantspain
« Reply #9 on: March 31, 2008, 03:17:30 pm »
good call from whammoed and most probably correct
newkillergenius
« Reply #10 on: March 31, 2008, 05:17:31 pm »
OK, we'll give 'er a try for a few days...   its hard playing it!    :P
« Last Edit: March 31, 2008, 07:40:12 pm by newkillergenius »
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #11 on: March 31, 2008, 06:19:53 pm »
rough handling in shipping can cause problems . a warped shadow mask for one .
suggest advising the shipper of the situation - just in case ....
repeated manual deguassing  may eventually clear it,  provided no internal crt damage.
qrz
Mauzy
« Reply #12 on: March 31, 2008, 06:56:28 pm »
I just duct taped two speaker magnets to a 1" paddle drill bit, pointed it at the center of my monitor, and spun it at full RPM while pulling back slowly worked great.
Although, the problem was started by the same magnets before I fixed it, so the magnets for the damage and repair were the same strength. That may have something to do with the way it turned out....
From a previous thread.
I still have a G07 in my Ms Pac cocktail, never got around to rewiring the degauss coil (anyone have a diagram for that? please PM if you do...) It takes three or four power cycles with a couple minute interval to fully degauss.
edited for inserting wrong quote. d'oh...
newkillergenius
« Reply #13 on: April 01, 2008, 09:24:16 am »
Just want to be sure before I completely ruin it.
Ken Layton
  • Guru
  • Technician
« Reply #14 on: April 01, 2008, 11:36:02 am »
The built-in automatic degausser in all tv sets and monitors is not very strong. Also, it only works when the set or monitor has been turned off for 30 minutes at least.
Yes there are times when even a brand new monitor will need to be manually degaussed with a handheld degausser coil.
newkillergenius
« Reply #15 on: April 02, 2008, 11:54:00 am »
Thanks Ken, I guess that sinches it.  I spoke to a friend who is bringing a manual degaussing wand over on Saturday.  I hope I dont screw up.  Cheers everyone.
newkillergenius
« Reply #16 on: April 09, 2008, 06:41:24 pm »
OK, this is getting wierd.
So a friend brought over a degaussing coil.
Used it on the machine.
nothing changed.
We moved it to another section of the house.
The areas that were discolored before became correct, and OTHER areas became discolored.  We used the coil again.  Nothing changed.  Am I just doomed here?  There's a Donkey Kong cocktail sitting right next to it, and it had no gauss at all.
What the hell is going on here?  :hissy:
grantspain
« Reply #17 on: April 09, 2008, 06:52:36 pm »
maybe you have a magnetised frame bolt or your transformer is a bit close to the monitor
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
« Reply #18 on: April 09, 2008, 08:33:22 pm »
Couple of things, probably already in the thread, but to degauss start at the center of the tube, with the degausser on.. circular motion from the center and work towards the outsise of the tube - all this say about 6 inches from the tube... now still with power on  pull the hand degausser nack about 6 feet.. now power off.
My guess still bad.
This is because when the monitor was made it was built as if it was a horizontal monitor, you have turend it vertical... pull the monitor and position it in a noarmal horizontal direction - if possible tube should face east. Now degauss it.. my guess is ok. If not the tube was aligned in a magentic field such as china.. huge difference in magnetic fields.
Let me know how you make out with this and I will be happy to try to help.
Good luck
Rick@niemandisplays.com
Always happy to help.., for the best in displays
Rick Nieman
Rick@Niemandisplays.com
www.niemandisplays.com
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
Denverlatino
  • ---Buyer Beware - transactions with this user are in dispute--- ... Banned ...
  • Last login:May 13, 2009, 02:55:24 pm
« Reply #19 on: April 09, 2008, 08:53:40 pm »
nothing changed.
When i posted this thread http://forum.arcadecontrols.com/index.php?topic=78754.0 i thought i was the only one with that problem,my solution is moving the game to the center of the room and the colors look right, hope someone will come with a fix for this one.
[transactions in dispute -- see http://forum.arcadecontrols.com/index.php?topic=77030.0]
... Banned ...
newkillergenius
« Reply #20 on: November 17, 2009, 10:00:27 am »
Sorry for the long delay in updating this thread, but we were never able to get it to stop happening.
Then, I moved to a new house.  And it stopped.
 :dunno
Rickn
« Reply #21 on: November 17, 2009, 06:20:40 pm »
No from the sounds of it you will not get it to go away.
The monitor was aligned/adjusted in it's normal upright orientation, now you have turned it on it's back. Huge difference in magnetic fields. This is compounded when facing Nort or South.
It cab be fixed by adjsuting the first 2 "rings" on the neck of the tube. You would have to break the seal on the rings, sometimes paint, some times hot melt.
Mark the current settings of all rings with a white china marker or pencil crayon. Chances are you will have to rotate those first 2 rings as a pair (Maintain their spacings) slightly clockwise.
Another way is to add magnets to the bell of the tube in the corners taht are bad. Problem is you will not have the magnets.
good luck Rick
Rick Nieman
519-621-1722
Kevin Mullins
    • Me on Myspace
« Reply #22 on: November 17, 2009, 09:24:48 pm »
Poltergeist interference maybe.  :dunno
speedklz
  • Last login:November 17, 2018, 12:56:23 pm
« Reply #23 on: November 18, 2009, 10:30:26 am »
Could be that the house has wire run through metal conduit or just alot of not well shielded wire in the wall and it is causeing a EM field in that house. That would be why when the this was moved it changed the part of the screen affected. Thats also why when you took it out of the house that it worked fine.
Thank Ghost Hunters for the EM suggestion   :lol
Best of the Best of the Best. Sir!
Ginsu Victim
  • Last login:June 08, 2026, 03:12:14 pm
  • Comanche, OK -- USA
« Reply #24 on: February 19, 2010, 11:39:25 am »
Now we know who bought the haunted Ms Pac machine.
newkillergenius
« Reply #25 on: March 09, 2010, 04:05:02 pm »
It's not the same one.  It does seem to have a similar problem though.
