Author Topic: Arcade Power Supply and Misc Part  (Read 1066 times)
trustno1
  • Last login:March 28, 2008, 11:32:06 am
« on: March 28, 2008, 11:32:37 am »
I was wondering if I could use the existing power supply (which has 120v wire (line, ground, neutral), and dc (+5, -5, +12, gnd)) to power by cabinet. Idea being to split the 120 to a power strip, and the isolation transformer for computer and moniter) then also using the dc for +5 for ledwiz and +12 for cathode and a couple fans. I was wondering if this would be sufficient and safe =). also their is another item which I am not sure what it does but was inbetween the jamma board and dc output of the ps. It is on the left of the picture. Thanks for the help.
Ken Layton
  • Guru
  • Technician
Re: Arcade Power Supply and Misc Part
« Reply #1 on: March 28, 2008, 12:18:36 pm »
This obviously came from a Dynamo cabinet. That's a load resistor next to the power supply. Some Dynamo cabinets were shipped with that to provide a minimum load on the power supply as some gameboards did not draw enough current on the +5 volts line to get the power supply to start up consistently.
That black cable should be the 120 vac ouput from the power supply to power the rest of the cabinet. Should be a black, white, and green wire terminated in a 3 pin white Molex connector. Power coming out of this connector is controlled by the power switch on the power supply. This power output cable was intended to go to a power distribution block in the game cabinet where the fluorescent light fixture, isolation transformer power input, and dollar bill validator (if fitted) would all connect. Remember only the monitor is to be connected to the output of the isolation transformer.
