Author Topic: what am i suppose to do after the last coat of paint?  (Read 2046 times)
clickhea
  • Last login:August 09, 2019, 07:33:40 am
« on: March 26, 2008, 09:07:52 pm »
a) leave it
b) sand it very very very lightly and leave it or apply clear coat
TelcoLou
  • Four score and seven years ago our fathers brought forth on this continent, a new nation
  • Last login:October 14, 2010, 01:28:19 am
  • Playing video games since 1977
Re: what am i suppose to do after the last coat of paint?
« Reply #1 on: March 26, 2008, 10:07:12 pm »
Well, depends on the type of paint. Is it acrylic? Then you might want to give it a clear coat.
On my cab, I just sanded down the original finish, painted with 2 coats of oil-based enamel (egg-shell finish) rustoleum paint, and let it dry. Looks great IMHO  :)
So a leper walks into a bar and as he gets his beer, a finger falls off. The bartender who is serving him turns and pukes all over the place. The leper, feeling bad, says, "Was it my finger falling off?" The bartender turns to him and says, "No, it's the guy dipping chips into your back."
rlemmon
  • Last login:April 06, 2022, 02:54:46 am
« Reply #2 on: March 26, 2008, 11:24:29 pm »
If it looks good leave it alone i wouldnt think sanding would be a good idea it might mar the surface.
TheShanMan
    • My Arcade (updated 1/30/13)
« Reply #3 on: March 26, 2008, 11:46:30 pm »
I'm kinda wondering the same thing - I'm almost to that point. Sand with a very high grit paper and then buff???
clickhea
« Reply #4 on: March 27, 2008, 11:08:47 am »
iam using black eggshell
Jakobud
  • Last login:April 07, 2026, 10:10:56 pm
« Reply #5 on: March 28, 2008, 02:31:54 pm »
Go over it once with some high-grit sandpaper.  Nothing rough or hard.  Just a light once-over.  It helps and will not mar the paint.
knave
  • Last login:March 24, 2026, 03:52:12 pm
« Reply #6 on: March 28, 2008, 04:04:37 pm »
Is this a situation where you would want to wet sand with some really high grit paper and some type of polish?
spacies
« Reply #7 on: March 28, 2008, 08:42:44 pm »
PLAY IT!
RetroACTIVE
  • Last login:January 28, 2024, 04:27:52 pm
  • Gramps
« Reply #8 on: March 28, 2008, 09:22:08 pm »
s t o p!
Happy Gaming!
ediblegod
  • Last login:October 30, 2017, 01:36:32 pm
« Reply #9 on: March 29, 2008, 01:41:16 am »
You guys ever consider laminate instead of paint?
Much more professional results...
Franco B
« Reply #10 on: March 29, 2008, 08:55:46 am »
Yep, just check out somunnys project > Clicky
Me, im going for vinyl and laminated carbon fibre.
