Author Topic: MAME.098b command line. (how do i get all games vertical)  (Read 1786 times)
BUCKETHEAD
  • Last login:April 04, 2024, 07:31:52 pm
  • Don't hate the player .... Hate the Game
« on: March 24, 2008, 10:07:01 pm »
I know this may be an easy question?
I have never fooled around with the command line version of mame.
How do i get my games vertical?
I know in mame32, You can just choose clockwise in default game options.
How do you do this in command line version?
Thanks so much!
Ummon
  • Trade Count: (+13)
Re: MAME.098b command line. (how do i get all games vertical)
« Reply #1 on: March 25, 2008, 04:57:40 pm »
Set is so in MameUI. Throw the vanilla mame files in the same folder. Run vanilla mame. Exit game. Go into your ini folder and copy the MameUI ini to the main folder and rename to 'mame'. Run vanilla mame.
Yo. Chocolate.
Stephen Hawking
shock_
  • Last login:January 30, 2020, 06:23:29 pm
  • In Brisbane, it's GMT+10 all the time.
« Reply #2 on: March 26, 2008, 08:48:35 am »
You want two particular settings in your .ini file(s) to be set correctly.
One is "norotate" - in mame 098 this defaults to off, meaning that "vertical" games will be rotated to suit the orientation of your monitor so you can play them on a normal PC.  Turn that on, or add a "1" or something.
The second is "autoror" or "autorol".  Some vertical games were originally counter-clockwise-rotated from the "top" of the 4:3 tube, and others clockwise-rotated.  Each game might be different.  If you've got a monitor mounted vertically, you will want "autoror" or "autorol" to force it to display the right way up for your monitor.
You can put these settings in your mame.ini file, or perhaps quicker you can test them out on the command line like this:
mame.exe galaga -norotate -autoror
This is almost from memory, so you may need to experiment a little but this works very well when you get the right settings sorted out.
Check the documentation (mame/docs folder) and look for these options:
-[no]norotate
-[no]ror
-[no]rol
-[no]autoror
-[no]autorol
-[no]flipx
-[no]flipy
BUCKETHEAD
« Reply #3 on: March 26, 2008, 08:28:03 pm »
Thanks guys!
All this is much appreciated!   :)
