Author Topic: 3/4" plywood: What size biscuits???  (Read 8966 times)
ArtsNFartsNCrafts
  • Last login:October 12, 2020, 09:22:50 pm
« on: March 23, 2008, 02:23:50 pm »
Hey guys.  Subject line says it all.  What size biscuits would I need to use if I'm using 3/4" plywood?  I'm fixing to construct the control panels for my cocktail...
shardian
Re: 3/4" plywood: What size biscuits???
« Reply #1 on: March 24, 2008, 08:56:12 am »
#10 should be more than adequate for cocktail CP's
« Last Edit: March 24, 2008, 09:17:25 am by shardian »
  • Last login:Yesterday at 03:06:24 pm
« Reply #2 on: March 24, 2008, 09:21:53 am »
I can confirm #10s as well.  It's what I used on my current cabinet and they are small enough to not pop through on a 45 degree angle as well.  It is solid.   :cheers:
sstorkel
  • Last login:November 08, 2011, 09:04:03 pm
« Reply #3 on: March 24, 2008, 07:28:57 pm »
If I were going to use biscuits, which I wouldn't, they would probably be #20s. Unless you're joining narrow pieces, you might as well go for the widest biscuit you have available. Thickness should be the same regardless of the size.
ArtsNFartsNCrafts
« Reply #4 on: March 29, 2008, 12:35:07 pm »
Thanks guys!  I think #10's should do it!
