Author Topic: WGU2000 Vertical Deflection  (Read 3003 times)
ToplessZ
  • Last login:December 08, 2018, 09:55:34 pm
« on: March 22, 2008, 11:59:46 am »
Well I have a WG U2000, When I first turned it on I have a 3 inch spread of picture from left to right (horizontally,no top and bottom) across the screen and couldnt adjust it out.  I bought and installed the WG Vertical Sweep Kit, and now I just have the same 3 inches but its all green now and I cant see any part of the picture.  Should I remove the vert kit and try the U5000's horizontal kit?  Do you think the power supply update kit could fix this?
Any thoughts as to what to do now?
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: WGU2000 Vertical Deflection
« Reply #1 on: March 22, 2008, 12:27:50 pm »
this is a monochrome vector monitor.  thus, the vert and horiz deflection circuits are the same ...
schematic at    www.freeinfosociety.com/electronics/schemview.php?id=2219
check for poor solder connections- u will likely find some .
check c203 2.2uF/50v and semiconductors for leakage or low gain
there may also be vert/horiz gain ctls on the game board.
it wouldn't be a bad idea to change 'lytics on the hv pcb while ya got it open
qrz
« Last Edit: March 22, 2008, 01:08:13 pm by qrz »
SirPeale
  • Green Mountain Man
« Reply #2 on: March 22, 2008, 08:16:45 pm »
He's talking about a U2000, what are you talking about?  :D
qrz
« Reply #3 on: March 22, 2008, 10:25:50 pm »
OOOPPPSS ! had pulled a V 2000.   sry,still adjusting to the new bifocals .... TNX for catching that Peale
lets try    www.freeinfosociety.com/electronics/schemview.php?id=2215
for narrow horiz deflection:
check the solder connections at c724 ,c722,cn206 and pin 1 of flyback
 and check d706 and q710 for leakage or shorts .
for vert issues :
check c607,610,613,615,616 and d683
also check r303,d302 and c306 in 30v supply
the tda1771 may also be faulty
qrz
ToplessZ
« Reply #4 on: March 23, 2008, 09:30:07 am »
wow, thanks.. Ill start the checking those components...I just replaced the TDA1771 but I ordered 10 of them from mouser so I'll try another one just in case
Ken Layton
  • Guru
  • Technician
« Reply #5 on: March 23, 2008, 12:15:08 pm »
And the monitor has had a fresh capkit installed?
ToplessZ
« Reply #6 on: March 23, 2008, 03:38:17 pm »
actaully no, the monitor has not been capped yet.  I was having trouble finding a cap list and I didnt feel like ordering one that was assembled already.
I did notice a small descrepancy in the vert kit.  The top of the page says to use a 100uf 35v cap, and in the directions it says to use a 100uf 50v cap.  The kit came with a 35v one so thats what I used.  The one that was previously installed was a 50v.
« Last Edit: March 23, 2008, 04:46:21 pm by ToplessZ »
grantspain
« Reply #7 on: March 23, 2008, 03:59:28 pm »
the problem with the green is most likely the drive transistor short on the neck card,worth checking these components
Q510, R562, R563, Q504, Q507, IC U500
Kevin Mullins
    • Me on Myspace
« Reply #8 on: March 23, 2008, 10:15:00 pm »
C613 - 100uf 50v according to the kit list and instructions I have seen.
If the voltage value of the original installed is higher than the replacement........ go with the higher voltage value. Discrepancies have been known to happen in kits.
EDIT: Hmmmm..... both the U2000 and the U5000 schematics show a 100uf 35v for C613.
I wonder if someone had replaced that cap on yours before.
Using the 50v in place of the 35v is fine of course.
« Last Edit: March 24, 2008, 12:41:25 am by Kevin Mullins »
Ken Layton
  • Guru
  • Technician
« Reply #9 on: March 24, 2008, 01:23:41 am »
The voltage of that capacitor was changed from 35 volts to 50 volts after the manuals & schematics were printed.
Kevin Mullins
    • Me on Myspace
« Reply #10 on: March 24, 2008, 07:06:28 pm »
Ah.... makes more sense now....thanks Ken.
