Author Topic: jamma vs jamma plus?  (Read 4831 times)
mrserv0n
  • Last login:May 25, 2021, 09:20:06 pm
« on: March 22, 2008, 10:21:19 am »
Hi this arcade cab has a JAMMA+(plus) system , what does the plus do and will it effect a jpac or is it the same as my regular jamma harness for a jpac
pcb
  • Last login:September 25, 2019, 05:27:26 pm
    • MikesArcade.com
Re: jamma vs jamma plus?
« Reply #1 on: March 22, 2008, 08:07:59 pm »
JAMMA+ simply means they used additional connections for the game, than the JAMMA standard allowed for.  JAMMA is the card edge pinout, any extra connectors for more than 3 buttons is probably on a separate harness.  Trackballs are usually also on a separate harness.
FYI, Almost all games that are JAMMA only use a subset of the pins as needed by the game, so even if a cabinet has a JAMMA game in it, it doesn't mean all the signals are hooked up to controls.  A good example of this is the -5VDC.  Most JAMMA games only need +5 and +12, so they don't bother hooking up the -5VDC lines to the power supply.
HTH! Best,
 - Mike -
mrserv0n
« Reply #2 on: March 23, 2008, 12:26:37 pm »
Ok, I just wanted to make sure the harness wasn't a difference size, thats fine as long as its a seperate harness for the 3 buttons
Spaz Monkey
  • Last login:February 15, 2011, 11:33:55 pm
  • Hit me with a chicken quesadilla and a Coke.
« Reply #3 on: March 23, 2008, 04:47:07 pm »
CPS2 board with a kick harness is a classic example of JAMMA Plus
