Author Topic: Cap kit just because?  (Read 1996 times)
Doormatt
  • Last login:May 13, 2008, 03:08:34 pm
« on: March 20, 2008, 01:52:54 pm »
I've got a K7000 series monitor that seems to be working fine, and based on the build date, seems about 12 years old.  Should I cap it just because I can, or would it be best to leave good enough alone?
I assume it doesn't need to be capped, but I'm starting to get curious if its working as well as it could be.
Thoughts?
SirPeale
  • Green Mountain Man
Re: Cap kit just because?
« Reply #1 on: March 20, 2008, 02:20:25 pm »
The rule of thumb with coin-op stuff is: if it's working fine, DON'T SCREW WITH IT.
Seriously.
Unless you're having problems with the geometry or shrinking or brightness, leave well enough alone.
Doormatt
« Reply #2 on: March 20, 2008, 02:49:50 pm »
*nods* That's what I figured.
I take it I'd notice something pretty significant if I needed a cap kit?
Mrjamma
  • Last login:April 01, 2009, 04:28:41 pm
« Reply #3 on: March 21, 2008, 10:23:48 am »
If it is working fine, dont waste your time with a cap kit.
However, caps have a working and/or shelf life of about 10 years.
After that time they start to leak or loose their efficiency.
Their performance does start to degrade after as little as 3-5 years.
(of course, I am not talking about the latest batch of garbage capacitors I have been
seeing the past 5 years or so. They blow up or short in about a year or less)
« Reply #4 on: March 21, 2008, 10:35:41 am »
I'd buy one and keep it on hand for when it does need a cap kit.  It is definite that it eventually will.
SirPeale
« Reply #5 on: March 21, 2008, 11:56:38 am »
I wouldn't.  When it does, I'd want the freshest one possible.
