Author Topic: Need Bezel Ideas  (Read 2886 times)
eschmunk
  • Last login:May 03, 2017, 05:03:33 pm
Need Bezel Ideas
« on: March 18, 2008, 02:51:49 pm »
I am about 95% done with my cabinet.  It has been in the same state for quite some time (read "year or two").  What I need is some ideas on what to do for a bezel.
Currently I have a 27" Sony TV that I am wanting to hide.  Any ideas?
Thanks in advance.
-e
Ginsu Victim
  • Comanche, OK -- USA
clickhea
  • Last login:August 09, 2019, 07:33:40 am
Re: Need Bezel Ideas
« Reply #2 on: March 18, 2008, 03:45:41 pm »
the bezels from happ wont work?
Ginsu Victim
« Reply #3 on: March 18, 2008, 03:52:40 pm »
Unless it's an arcade monitor, it probably wouldn't be a perfect fit.
clickhea
« Reply #4 on: March 18, 2008, 05:19:06 pm »
i cant believe theres no companys out there that make bezels for tvs being that this is such a popular thing.
Ginsu Victim
« Reply #5 on: March 18, 2008, 05:25:47 pm »
They would have to make too many, or only do custom jobs.
It's too difficult to do it for every type of TV and computer monitor.
somunny
  • Is it hot in here?
« Reply #6 on: March 18, 2008, 05:57:23 pm »
I bet the Happ bezel would be pretty dang close.  The problem with most TV's is that you can't adjust the horizontal and vertical spread of the picture.  With a pc monitor, you can make the pic fit the bezel.
I have a file with the Happ 27" bezel measurements at home.  I'll post it for you.  Maybe it will do the job.
eschmunk
« Reply #8 on: March 19, 2008, 02:58:32 pm »
I was thinking about the Happ's Bezel but didn't want to spend the money on something where shipping cost twice as much as the item itself and may not work.
Ginsu Victim
« Reply #9 on: March 19, 2008, 03:03:29 pm »
Foam core board and poster board
Combined they work wonders.
About $4.00-6.00
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #10 on: March 20, 2008, 01:01:52 pm »
And many original cabs had black poster board bezels.  Pole Position for example.
Robin
Knowledge is Power
clickhea
« Reply #11 on: March 20, 2008, 02:10:08 pm »
why arent people making bezels out of wood?
Ginsu Victim
« Reply #12 on: March 20, 2008, 02:18:28 pm »
In the case of my cabinet, there's not much room between the monitor and the plexi, so I just have a black foam core board, plus black posterboard with my art/instructions on it. No room for wood.
Plus, posterboard has been used since the beginning on a lot of machines.
specksynder
  • Last login:February 20, 2011, 05:31:31 pm
« Reply #13 on: March 20, 2008, 03:05:46 pm »
here's what I did that looks great -- get black, foam, pipe insulation from Lowe's (or HomeDepot).  It wraps around the pipe and has some adhesive that joins the foam into a cylinder.
Cut the stuff in half lengthwise so you have a half-cylinder.  use the adhesive to stick the foam to the side of your monitor.  the foam makes a smooth black bezel.
For my cocktail, it works perfectly.  (and cheap)
clickhea
« Reply #14 on: March 20, 2008, 03:20:38 pm »
can you supply some pics spec
severdhed
  • RIP Dinosaur Hippo
« Reply #15 on: March 20, 2008, 03:37:40 pm »
i just taped off the screen area and spray painted the back side of my plexiglass.  this gives you a very glossy finish that looks great.
rlehm
  • Last login:September 30, 2010, 09:04:25 pm
« Reply #16 on: March 20, 2008, 03:56:19 pm »
i ordered a happs bezel. since my tv wasn't as much of a bubble as a monitor, i just ordered their flatter one. i had very very little modification to make. i just had to trim the widthXheight. But, I always have to do this even with dedictaed arcade cabs, so nothing new.
solderguy1
  • Last login:November 19, 2016, 01:29:27 am
« Reply #17 on: March 20, 2008, 11:07:19 pm »
I have a rotating LCD, so I'm gonna try a two prong approach, one sheet of black contruction paper border attached to the monitor and one taped to the smoked bezel glass.  It's gonna be tough to get all the bordering and circles right.
