Author Topic: How do I change directions the mouse goes?  (Read 1587 times)
IceCold
  • Last login:March 22, 2010, 05:11:22 pm
    • My MAME cabinet webpage
« on: May 23, 2003, 08:11:03 pm »
I have a question, how do I make it so that when I move vertically with my mouse, it moves horizontally on the computer.  I did a mouse hack that was like 500 times easier if I hacked the vertical optics than the horizontal, so I hacked the vertical.  Anybody have a program or some type of software that will make my vertical movements horizontal on the pc?
Thank you.
gtjoe
  • Last login:November 04, 2006, 05:06:20 pm
Re:How do I change directions the mouse goes?
« Reply #1 on: May 23, 2003, 08:29:53 pm »
Not sure... but I think the only way to support this switch is by using the Mame:Analog+ at www.urebelscum.speedhost.com
IceCold
« Reply #2 on: May 23, 2003, 08:34:04 pm »
If the software really switched it though, then wouldn't it work in normal MAME(since the software had already switched it)?
IceCold
« Reply #3 on: May 23, 2003, 08:35:46 pm »
Now that I think about it(yes, I can think) I'll just wire the vertical optics electrically to where the horizontal optics are.  Then I won't have to do any mounting or anything, just solder a few wires.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #4 on: May 24, 2003, 07:27:00 am »
Yes, you can do is.  Quick and easy hardware solution.
Analog+ can reassign mouse's axis, so you could assign mouse Y axis to the game's player 1 X axis, but it would only work in Analog+.
A very few mouse drivers can reassign the mouse axes for windows, which should also effect mame.  I don't which drivers, though.
If I was you, I'd go with the hardware fix.  If I was me (hey, I am me :P ), I'd do the Analog+ way. ;D
Robin
Knowledge is Power
IceCold
« Reply #5 on: May 24, 2003, 12:06:13 pm »
I tried the hardware fix and accidentally melted my mouse wheel thing  :( , so I had to superglue a new one on, and now it's not perfectly level, and the spinner doesn't work as well  >:( .
I probably should try the hardware solution again, and just make sure my wheel is nowhere near it.
