Author Topic: Converting 24hz to 15/31hz  (Read 2814 times)
iMPULSZE
  • Last login:May 23, 2009, 10:32:04 am
« on: March 14, 2008, 08:25:17 am »
I have a large monitor that I'd hate to get rid of, but it was a dedicated monitor for a Sega Model 3....  thus its 24hz.  I want to be able to play other games that output at 15/31 hz.  Is there anything that I can do to the monitor so that I can convert it to the Hz I need?
grantspain
Re: Converting 24hz to 15/31hz
« Reply #1 on: March 14, 2008, 09:47:37 am »
are you sure the monitor is not a dual sync or multi sync,whats the model no.?
iMPULSZE
« Reply #2 on: March 15, 2008, 07:16:56 am »
Its a 50" Mitsubishi RPTV....
Game Name:     Virtua Fighter 3
Cabinet Type:    Deluxe
Monitor Size:    50" ( PTV )
Model Number:    VS50-SE1
Sega Part Number:    2001-5265
Monitor Maker:    Mitsubishi
Flyback Number:    998-0066 Thru 0069 Tubes & Lead
Country made:    USA
Voltage:    120v
Resolution:    Med(24Kx60)
Chassis Number:    998-0054 Thru 0060
Are these dual sync?
Manual Part Number:    999-0622
grantspain
« Reply #3 on: March 15, 2008, 01:16:27 pm »
as far as i am aware these are 25khz only,they are common on sega dx cabs(i have 8 of these)
i will have to ask a friend if its switchable to 15khz as i have never tried it
iMPULSZE
« Reply #4 on: March 15, 2008, 10:44:12 pm »
Yes, if you could, please let me know if theres some kind of work around.  I'd really love to play my Naomi on it.
Gehrig
  • Last login:January 11, 2009, 12:21:06 pm
« Reply #5 on: March 17, 2008, 09:58:17 am »
Thought I read somewhere that only the smaller monitors where switchable.  Can't seem to find that info now though.
Edit: Hmmm maybe not.  You may want to contact Andy Geezer to make sure.
Check this thread:
Code: [Select]
http://www.neo-geo.com/forums/showthread.php?t=17489
« Last Edit: March 17, 2008, 10:04:52 am by Gehrig »
grantspain
« Reply #6 on: March 17, 2008, 11:55:07 am »
according to tony at dh leisure these were built for the arcade cab only and therefore 25khz only
