Author Topic: super Happ stick won't stay  (Read 1343 times)
LoyalistRevolt
  • Last login:June 19, 2008, 08:52:07 am
  • SEGA!
« on: March 10, 2008, 10:19:04 pm »
well this black thing on my super happ joystick keeps slipping off at the bottom how can I make it stay?
Not posting doesn't make you a noob, ignorance, stupidity, laziness, and talking trash make you a noob.
Just cause I don't post in threads doesn't mean I don't read the threads...
mrserv0n
  • Last login:May 25, 2021, 09:20:06 pm
Re: super Happ stick won't stay
« Reply #1 on: March 11, 2008, 12:17:00 am »
Are you reffering to the 4/8way little plastic knub? With your stick you should have recieved a little metal piece that slides onto the shaft of the stick. Check your wrappings to be sure it wasnt over looked
paigeoliver
  • Awesome face!
« Reply #2 on: March 12, 2008, 03:48:19 am »
If it is missing then ACE/True Value hardware store stocks them (as do most other hardware stores). Don't go asking for joystick parts though, it is just an off the shelf retaining clip thing.
Oddly enough I have also replaced missing screw-off joystick knobs at the hardware store too, right in the same part of the store.
