Author Topic: Help! Where do I connect my degauss circuit?  (Read 2260 times)
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« on: March 08, 2008, 09:49:52 pm »
I messed up. I took "before" photos of cable connectors on this monitor in a Taito cocktail table so that I would know where things go. But I missed taking a shot of where the degauss circuit connects to. As luck would have it, now I seem to have 3 different spots where this connector could conceivably attach to!
The connector is a 3-position connector (with a gap making it kinda the same as a 4-position connector), but only has 2 wires going into it.
Photos below. I have NO idea what brand monitor this is. It's 13", has a 12-pin tube and the flyback is mounted separately from the chassis. Looks to be original for this cocktail but the tube probably is not. (Toshiba brand tube)
« Last Edit: March 09, 2008, 09:01:06 pm by RayB »
NO MORE!!
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: Degauss circuit is usually driven by ?
« Reply #1 on: March 08, 2008, 09:55:55 pm »
chassis # or a pic would be helpful.
 barring none, the 3rd option most likely . especially if near the thermistor ...
qrz
RayB
  • There's my post
    • RayB.com
« Reply #2 on: March 09, 2008, 08:55:49 pm »
Here are pics. Note I was unable to remove the chassis from its mounting, so I could not explore what stickers or labelling it has in locations I can't see.
I've circled in green the two sockets I think one of which the degauss wires are supposed to connect to.
Anyone recognize this??
NO MORE!!
RayB
  • There's my post
    • RayB.com
« Reply #3 on: March 09, 2008, 08:57:09 pm »
More pics...  Pic 2 here shows a 3rd possible connection point, but I'm 95% sure it's not it.
NO MORE!!
qrz
Re: Help! Where do I connect my degauss circuit?
« Reply #4 on: March 09, 2008, 10:24:04 pm »
th601 is the thermistor and the coil connection is beside it .  normally ,there are only two lugs on the connector.
perhaps the mfg got a "deal" on the 3pin plug  :dunno
qrz
Ken Layton
  • Guru
  • Technician
« Reply #5 on: March 09, 2008, 11:35:21 pm »
You have a Wells-Gardner 13K4700 monitor. The degausser plugs into that two pin connector with "R602" silkscreened below it.
RayB
  • There's my post
    • RayB.com
« Reply #6 on: March 10, 2008, 01:07:12 am »
Wow Ken, you're amazing (as always). thanks
NO MORE!!
