Author Topic: How thick is the glass on the front of a CRT?  (Read 7628 times)
Mauzy
« on: March 07, 2008, 11:51:29 pm »
I have a 26" Phillips Magnavox TV that I was thinking of MAME-ing, but it has a couple chips in the screen. I've used this TV on a daily basis for 4 years with the chips in it, but it got me to thinking: How thick is the front part of the glass on a CRT? How deep of a chip can it have before being deemed unsafe?
brandon
  • Last login:December 26, 2025, 08:29:45 pm
  • I <3 arcade games.
Re: How thick is the glass on the front of a CRT?
« Reply #1 on: March 08, 2008, 12:29:08 pm »
its VERY thick!  I tried like hell to break a CRT in a dumpster once and didnt have much luck.  I would guess its at least 1-3"thick in places. That's why they're so darn heavy.  I dont think a chip would make a CRT unsafe.  Its not going to leak out nerve gas or anything like that :)
Mauzy
« Reply #2 on: March 08, 2008, 04:03:53 pm »
Ha. Wow. I figured it would be thick, but not that thick.  Thats rather handy to know...
Ummon
  • Trade Count: (+13)
« Reply #3 on: March 08, 2008, 06:28:15 pm »
Notice when you put your hand on the glass and the image seems a bit away? Because it actually is.
Yo. Chocolate.
Stephen Hawking
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #4 on: March 08, 2008, 10:04:22 pm »
 as the screen size increases , thicker glass is required due to atmospheric pressure on surface area.
thats also why the neck can be so thin .  smaller surface area ......
qrz
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
« Reply #5 on: March 09, 2008, 03:32:49 pm »
The glass is about 3/4" thick. During the manufacture of the tube various tests are done to insure it meats UL requirements. These tests are not done on evert tube, just a sampling.
- first off the tube is positioned in a jig so that it is upright, it has a 7 Joule impact test. what this meams is a solid metal object shaped like a bulllet weighing 7 pounds is suspended on a rope like a pendulum, pulled back in a 7 foot arc and then let go so that it hits the center of the tube.... it cannot break or it fails.
- next the glass is frozen with nitrogen and the glass is scribed, the test is repeated and this time it will break, the glass cannot fall outside a line that is about 5 feet form the tube.
Bottom line your tube is probably safe, if it had chips around the "Frit seal" ( this is the white/grey seal that joins the faceplate to the tube) then it is a different story.
Hope this helps
Always happy to help.., for the best in displays
Rick Nieman
Rick@Niemandisplays.com
www.niemandisplays.com
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
Mauzy
« Reply #6 on: March 09, 2008, 04:49:32 pm »
Thanks everybody. The chips are in the center of the viewing screen, so I guess Im safe.
