Author Topic: Are joysticks meant to go under the CP or routed into the CP?  (Read 1804 times)
Cero21
  • Last login:February 23, 2016, 11:04:44 pm
I'm confused.  I have some Happ Supers and I was wondering if I am supposed to mount them underneath the CP (and just fit the joysticks through 1" 1/8 holes) or rout a rectangle on top of the CP so that the lip sits in it?  I'm seen both ways in some other peoples projects...
RetroACTIVE
  • Last login:January 28, 2024, 04:27:52 pm
  • Gramps
Re: Are joysticks meant to go under the CP or routed into the CP?
« Reply #1 on: March 05, 2008, 11:57:03 am »
Does not particularly matter... many times it depends upon the thickness of the material you are using and the length of the stick... usually personal preference.
I like to mount them underneath, using t-nuts, then use plexi-art overlay... thereby hiding the mounting bolts.... plus if you mount them from the top you have to pull everything apart to get them out... from the bottom just remove the e-clip and unscrew the mounting bolts and your done!
« Last Edit: March 05, 2008, 11:58:50 am by RetroACTIVE »
Happy Gaming!
Afterburner
  • Last login:July 27, 2016, 01:02:00 am
« Reply #2 on: March 05, 2008, 01:09:20 pm »
I routed the underside of my CP to fit my 8-way rotary sticks.
I used countersunk machine screws that sit flush with the CP.  Then I have the CP artwork and plexi overlay so there are no fasteners showing on the top of the CP.
  2-player upright dual trackball / dual 8-way rotary joysticks - built from scratch
« Reply #3 on: March 05, 2008, 01:46:02 pm »
What happens if you need to get the sticks off?? Have you fixed the screwheads to the CP somehow?
