Author Topic: Mounting monitor in cocktail cab?  (Read 2093 times)
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:June 16, 2025, 09:16:27 pm
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
« on: May 21, 2003, 06:18:13 pm »
I put together a nice cocktail cab earlier today, but now I'm stuck on how
to get the monitor into it. It's a replica Ms.Pac-Man cabinet, at the moment
it's entirely empty. The monitor needs a vertical orientation.
I'm thinking that I could run two pieces of wood along the length of the
cabinet, about an inch from the top. Then somehow bolt the monitor onto
these pieces, so it rests in-between them.
Take a look at the photo below; where would I attach anything to this
monitor's frame? Its a WG9100 series, model 1891.
How are cocktail monitors normally mounted?
paigeoliver
  • Awesome face!
Re:Mounting monitor in cocktail cab?
« Reply #1 on: May 22, 2003, 05:14:32 am »
Cocktail monitors vary in mounting schemes. My Time Pilot mounts its monitor to a metal thingy that flips up, only takes two bolts. Jack the Giantkiller mounts to a wood frame.
In the case of yours I would screw a section of 2x4 onto that flat metal section on each side, which would allow you to make rails for it to sit on (that looks like a shelf mount monitor to me).
You will probably have to take the tube off the frame to screw the wood onto it.
JoyMonkey
    • JoyMonkey.com
« Reply #2 on: May 22, 2003, 03:09:07 pm »
Do you think this could work?
I got the bolt at the front of the monitor off and stuck a steel brace under it that I could now screw into a few wooden supports.
If I do the same for all 4 corners, do you think it'll be stable/safe enough?
paigeoliver
  • Awesome face!
« Reply #3 on: June 01, 2003, 10:26:03 am »
That should work just fine. Looks just as strong as the factory setup that holds my Time Pilot monitor in place.
phizzle
  • Last login:October 19, 2004, 01:44:58 pm
  • Trackballs, Spinners, and Joysticks OH MY!!
« Reply #4 on: June 02, 2003, 04:06:46 am »
i just purchased an old space invaders, and i was lucky the pc monitor i wanted to use with the shell off had the same exact mounting scheme as the space invaders monitor had, im so lucky, its a sign that im supposed to mame. so i mounted it like it was originaly and the bezel and everything is perrrfect.
Doug Sax  dnsax@yahoo.com aka Phizzle
