Author Topic: Cutting the bezzle  (Read 1637 times)
gamecaptor
  • Last login:October 15, 2004, 01:26:48 pm
Cutting the bezzle
« on: May 21, 2003, 04:00:45 pm »
I just bought a new bezzle for my arcade cabinet, but I need to cut it down to fit. What should I use so it makes a clean, solid cut?
paigeoliver
  • Awesome face!
Re:Cutting the bezzle
« Reply #1 on: May 21, 2003, 04:29:52 pm »
What is a bezzle?  ;D Is that like a bezel? If it is, then I have cut mine with a box cutting knife before.
AlanS17
    • AlanS17
« Reply #2 on: May 21, 2003, 04:55:38 pm »
Just score it really well with a utility knife (box cutter). You don't even have to go all the way through it. You don't have to saw it.
When you get a really good deep line you can actually rip it in a straight line.
gamecaptor
« Reply #3 on: May 21, 2003, 05:23:34 pm »
Cool, thanks for the advice. O-and yes, I meant BEZEL :)
Brad Lee
  • Last login:May 26, 2005, 11:39:04 am
    • 666
« Reply #4 on: May 22, 2003, 01:11:58 am »
Assuming it's plexiglass, this is what Ive done for long straight cuts
I usually tape off the straight line on the "good side" jsut to make sure that when Im cutting it stays straight. I've got 2 long metal straight edges, so I keep one right along the taped edge and repeatedly score it with either a razor blade widget thingy, or Ive got a regular plexi cutting blade(usualloy hanging right next to where you find the plexi) When it seems deep enough I square up the cutline right over the edge of a table or bench, still applying pressure on the straight edge, I then take the other one which is really a beam level(so its nice n sturdy) butt it right up to the edge of the other SE, at this point its hanging over the table and resting on the "scrap" piece.  Give it a good WHACK with a rubber mallet/coated ballpeen hammer right in the center of the level and it just snaps nice n clean. This works good on thin cuts- plexi usually comes in 24" width, but the size I need is about 23-1/2" SO theres not a lot of scrap to get a good hold on
If small pieces are left attached to the good side, I use a good clean pair of pliers, line it right up to where the cut should be and just apply a little downward pressure. 99% of the time it follows the score line and leaves it nice n smooth
