Author Topic: Quick Question about interfacing  (Read 1678 times)
Xb0x3r
  • Last login:August 06, 2010, 07:47:33 pm
« on: March 02, 2008, 05:20:14 pm »
I recently purchased an Outrunners cabinet in terrible shape for 25 bucks. From this I received 2 working arcade monitors.
Anyway, on to my question
I was just wondering if it is possible to harm an arcade monitor if I make a cable that will convert VGA into an RGB signal.
Thanks in Advance,
Xb0x3r
grantspain
  • Last login:September 08, 2026, 01:42:17 pm
Re: Quick Question about interfacing
« Reply #1 on: March 03, 2008, 09:48:23 am »
you can make a vga to monitor plug but if you feed it the wrong signal you will get 2 pics on screen,there is a debate whether vga signal can kill a 15khz arcade monitor-so if you want to run a pc onto the arcade monitor first find the model number and its spec then if its 15khz you will need either an arcade vga card
http://www.ultimarc.com/avgainf.html
or a vga card that can support custom settings with the correct software to run it.
http://forum.arcadecontrols.com/index.php?topic=66402.0
