Author Topic: VGA to Scart Lead construction question  (Read 3551 times)
FhM
  • Last login:February 26, 2018, 03:33:01 pm
« on: February 29, 2008, 12:31:09 pm »
Ok I have my cab running on Svideo at the moment just for testing and although playable I know it can be better. After a previous post of mine I was told to make myself a VGA to Scart lead. I was given the links to the relevant website and away I went with my prep.
I got myself a scart end and a VGA cable. I cut one end off the VGA cable and stripped back the wire. Now I am comfortable enough with a bit of soldering but I have a question regarding some of the wires. The wires in question seem to have a shielding around them and when I tested them they all seemed to earth to the metal on the VGA end of the socket. Now do I have to replicate this at the scart end or not or can I just cut it back?
tia
Chris
Mr Wilson
  • Last login:August 14, 2018, 01:24:44 pm
  • it never ends!!!!
Re: VGA to Scart Lead construction question
« Reply #1 on: March 02, 2008, 09:56:49 am »
i've just brought this
http://cgi.ebay.co.uk/2M-SCART-LEAD-TO-15-PIN-HD-VGA-SVGA-CABLE-UK-SELLER_W0QQitemZ180220014289QQihZ008QQcategoryZ41999QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
i'll let you know if it works but looks like it will for £5 it's not worth making your own but going have to run the 15khz software ;D
Grasshopper
« Reply #2 on: March 02, 2008, 10:21:04 am »
Interesting. I wonder whether that would work with an Xbox.
FhM
« Reply #3 on: March 02, 2008, 04:24:53 pm »
Thanks I will appreciate knowing how you get on.
SailorSat
  • Last login:August 31, 2026, 12:43:23 pm
    • For Amusement Only e.V.
« Reply #4 on: March 03, 2008, 01:53:36 am »
These Cables will NOT work as they are SCART->VGA, and you will need VGA->SCART
(Pinout most likely has other Sync-Pin at SCART Plug)
As for the earth ground wires on your cable, that should be fine as they actually are common ground on most VGA cards.
I do all that stuff even without a Joystick ;)
Soft-15kHz, cabMAME, For Amusement Only e.V.
FhM
« Reply #5 on: March 03, 2008, 12:02:34 pm »
So are you saying just earth the main shield and cut the rest back?
Mr Wilson
  • it never ends!!!!
« Reply #6 on: March 03, 2008, 12:27:50 pm »
dam! can any one make me one of these leads please as i said before i'm rubbish at soldering so if anyones up for making me one let me know
Cheers ;D
Mr Wilson
  • it never ends!!!!
« Last Edit: March 03, 2008, 12:53:21 pm by Mr Wilson »
FhM
« Reply #8 on: March 03, 2008, 01:13:53 pm »
The second one looks promising depending on your card but do you have a component input on your UK TV?
SailorSat
« Reply #9 on: March 03, 2008, 01:28:06 pm »
You most likely won't find any cable like the one you want, as it simply isn't a common thing.
Hell... Most non-EU TV don't even have any way to get RGB signal in.
As for component... I don't know how those cables work in detail, I suspect there are more or less simple RGB connections with "sync-on-green", which won't work with SCART either.
Mr Wilson
  • it never ends!!!!
« Reply #10 on: March 03, 2008, 02:38:48 pm »
ok thanks i'll have to wait till someone offers to make me one or try to improve my soldering skills
Level42
