Author Topic: multiple system connections  (Read 1366 times)
mastercave
  • Last login:July 07, 2003, 10:48:57 am
  • single player cp only
« on: May 21, 2003, 01:53:26 am »
how would you do this? i wanted to hook up my cp to the computer and the xbox so would it be 1 wire from the pushbutton splitting into 2, 1 going to computer and 1 going to xbox controller?
armad1ll0
  • Last login:March 28, 2012, 12:24:57 pm
  • The player and the builder!
    • Modeverything
Re:multiple system connections
« Reply #1 on: May 21, 2003, 05:32:34 pm »
hack in a Xbox controller for each joystick. Then order a Xbox to USB adaptor from lik-sang.com then you can put that dongle adaptor on there for your PC. You chouldn't do it the same time but you could switch it pretty easily.
mastercave
« Reply #2 on: May 22, 2003, 03:46:42 pm »
anyone know if these xbox to usb connectors are good? i had a ps2 to gc adapter once and once in a while it would stop working and i would have to disconnect and connect it again to make it work.
Hellfromabove
  • Last login:January 08, 2020, 05:45:41 pm
  • Soundwave Superior, Constructocons Inferior!
« Reply #3 on: May 22, 2003, 03:59:19 pm »
Yeah the X-Box to USB are good. Go to Lik-Sang and you can get a multi port box for it for cheap. Thanx.
-See Ya!!!
