Author Topic: heater/cathode shorts - i.e. bright 1 color pic w/horiz lines  (Read 1886 times)
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« on: February 23, 2008, 08:59:53 pm »
for those not wanting to wind their own filament winding ......,
the latest sales flyer from mcm (800 543 4330 or  www.mcmelectronics.com)   lists an isolated crt brightener  prt # 33-595
this is a transformer that will connect to the original filament winding (primary) then to the crt filaments ( secondary)
thus isolating the cathodes from the heater's ground loop .  the secondary voltage will be higher providing the brightener effect .  just add series resistance at proper wattage if no brightener needed....
haven't seen these available for a number of yrs !  and still cheaper to wind yer own   ;D
qrz
Ken Layton
  • Guru
  • Technician
Re: heater/cathode shorts - i.e. bright 1 color pic w/horiz lines
« Reply #1 on: February 23, 2008, 11:33:54 pm »
That's the 'brightner' that Star Tech Journal and Happ Controls sells at a higher price.
D_Zoot
  • Last login:November 18, 2010, 03:59:37 pm
  • Sorry if I get any spit on you...
« Reply #2 on: February 25, 2008, 09:15:35 am »
Actually, no resistor needed. Those isolators/boosters come with a number of leads to configure the unit for isolation only (no boost, or 1:1 ratio) or isolation and boost.  They also have leads to configure for Trinitron tubes, for those folks that see Sony tubes/monitors/TV's
MCM has had those for long time.  I'm too lazy to wind my own,  :)  so I've always kept one on the shelf.
D
qrz
« Reply #3 on: February 25, 2008, 05:33:48 pm »
been using MCM for a looong time . that was the 1st i've seen  ( noticed ??? ) they had 'em.
just not something i use ... a couple of feet of wire does just fine  ;)
tnx for the info .
qrz
grantspain
« Reply #4 on: February 25, 2008, 05:42:28 pm »
how does this function,how does it help the gun?
i have not seen these in europe
D_Zoot
« Reply #5 on: February 25, 2008, 08:25:30 pm »
It's really just a small isolation transformer for the heater circuit.  If you have a tube with a H-K short this will electrically isolate the heater so there is no longer an electrical "path" between H and K.
It can also be used to boost the heater voltage slightly.  If you have a weak or gassy tube, boosting the heater voltage can wring a little more oomph out of the guns.
Boosting the heater is a roll of the dice, only to be used as a last ditch attempt to save a weak tube.  It doesn't always help much or last very long and there is always a danger of blowing the heater filament open.  But if you are going to pitch a tube anyway, doesn't hurt to try!
D
