Author Topic: Are there issues with mounting monitors/tv's at angles?  (Read 1088 times)
ivwshane
    • My first mame cab! (WIP)
« on: February 21, 2008, 11:11:53 pm »
Obviously arcade monitors can handle being mounted at different angles but I don't know if that is because they are built that way or because it's really a non issue.
I have a tv I want to mount and I'm contemplating the various angles to mount it at but if there is a "life span" issue then I want to be aware of it before I come up with a final design.
pcb
  • Last login:September 25, 2019, 05:27:26 pm
    • MikesArcade.com
Re: Are there issues with mounting monitors/tv's at angles?
« Reply #1 on: February 22, 2008, 01:23:28 am »
If everything is attached properly in the case on the TV, there is no problem.
