Author Topic: My Giant trackball  (Read 2012 times)
Generic Eric
My Giant trackball
« on: May 19, 2003, 10:56:24 pm »
Ok, so I bought one of those Candlepin/Duckpin bowling balls.  The way about the same as the atari football trackballs.  The ball is 4.5 inches.  What I want to know is what do you suggest making the enclosure out of?  Metal? If so what kind and how thick?  If I make the trackball enclosure out of metal, should I still have a trackball mounting plate?
Is there anything else I need to consider?  Thanks in advance.
MinerAl
  • Last login:December 15, 2025, 06:28:31 pm
  • duck
Re:My Giant trackball
« Reply #1 on: May 19, 2003, 11:49:47 pm »
Are you building the mechanism yourself then?
Generic Eric
« Reply #2 on: May 20, 2003, 12:05:24 am »
Well, I looked for it at happs, but it was too pricey.
I don't know how much its gonna end up costing me in end, or if it would be cheaper just to buy it from happs.  But I think it can be done.  You have one, so you could probably tell me what I am getting into best
MinerAl
  • duck
« Reply #3 on: May 20, 2003, 01:24:20 pm »
Cool!
The thing about the Happs/Atari giant track balls, is that the mechanism is designed for mounting under a metal CP.  If you were to mount one even under a 1/4" of plywood, you would be seriously reducing the surface of the ball you'd have to play with.
If you're going to design/manufacture your own, you could make the top of the mechanism 3/4" lower, so that the ball could be mounted in a regular wood CP.
I'll do some measuring when I get a chance (which may not be soon, unfortunately).  How much access do you have to a metal shop?
Generic Eric
« Reply #4 on: May 20, 2003, 01:54:03 pm »
Not much to be honest.  There is a Fab guy at work, and I know he has contraption to bend metal for making brackets and stuff.  But im not sure what else he has in there.  Measurements would be great, I only have the exploded view from the happs website.  No rush and I didn't mean to put you on the spot or anything.
I didn't realize that the cps were metal, so the hint you gave me is a great help.
« Last Edit: May 20, 2003, 02:27:47 pm by generic_eric »
