Author Topic: Did midway make two pac man uprights?  (Read 6524 times)
neokidgeo
  • Last login:June 16, 2019, 03:12:39 pm
  • Uncle rico sends his love
« on: February 14, 2008, 05:02:49 pm »
Hi guys,
Sorry if this questions been asked before but i'm trying to find out if midway made two or more diffrent uprights? I've just picked up two boot leg namco shaped cabs and wondered how diffrent to the original namco ones, Heres the pic's of one of them and i was told there itlain made.
http://www.flickr.com/photos/10792211@N02/2265877308/
http://www.flickr.com/photos/10792211@N02/2265087223/
http://www.flickr.com/photos/10792211@N02/2265087405/
http://www.flickr.com/photos/10792211@N02/2265877796/
« Last Edit: February 16, 2008, 01:07:50 pm by Peale »
UkVacer
neokidgeo
Re: Did namco make two pac man uprights?
« Reply #1 on: February 14, 2008, 05:15:03 pm »
Few more pic's, sorry about the linking but i'm not sure how to up load them to the site  :-[
I also got a zaccaria frogger that i can also upload pic's of if anyone is interested?
http://www.flickr.com/photos/10792211@N02/2265896364/in/photostream/
http://www.flickr.com/photos/10792211@N02/2265896514/in/photostream/
http://www.flickr.com/photos/10792211@N02/2265105927/in/photostream/
UkVacer
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
Re: Did midway make two pac man uprights?
« Reply #2 on: February 14, 2008, 06:58:09 pm »
Click on the ADDITIONAL OPTIONS link when you post ...
Working: Not Enough
Projects: Too Many
Progress: None
Mauzy
« Reply #3 on: February 14, 2008, 10:53:42 pm »
Holy crap... where did you find that? Honestly, It looks a little...rickety... to be a factory cab, although IDK. Im really thrown off by that coin door.
At any rate, looks like its gonna take quite a bit of work to fix up. Who knows: you may have some crazy rare cab.
Possible cab for a Pac/Galaxian bootleg?
EDIT: Didn't see that you had two of them. Maybe an operator made em just to put surplus boards in? They both just have a quickly built without a ton of experience feel to them.
« Last Edit: February 14, 2008, 10:56:34 pm by Mauzy »
Level42
« Reply #4 on: February 15, 2008, 02:02:23 am »
Definitly bootleg. Nacmo's cabs were about the same as Midway's, but not 100%, but this is definitly nat Namco.
The Zaccaria is Italian of course, so these two others could very well be Italian bootlegs.Horrible job on the construction though...
Here's some nice pictures of a Namco Galaxian, as you can see it looks very much like the Midway version....in regards to the cab dimensions that is. I'd love to own that one :)
Nice score on the DK and Popeye cabs by the way !!
RobinHolland
  • Last login:March 13, 2013, 04:07:23 pm
« Reply #5 on: February 15, 2008, 02:33:29 am »
Zaccaria cab is same as mine  ;D
This is the first time  i see a zaccaria frogger site art
Nice score
« Last Edit: February 15, 2008, 02:35:48 am by RobinHolland »
paigeoliver
  • Awesome face!
« Reply #6 on: February 15, 2008, 04:47:26 am »
There are four official variants on that cabinet in the US market.
1 is plywood and usually held Pac-Man or galaxian.
The next is particleboard with slightly different curves and usually held Ms. pac or Galaga.
The next is Rally-X which is the Pac-Man cabinet, but shallower.
The final one is the Class of 81' cabinet which holds Ms. pac and Galaga together. It differs from the particleboard ms. pac cabinets by having a larger monitor, a different coin door and being of overall lower quality construction.
There were also multiple european variants and a few japanese variants, although you are unlikely to ever see a japanese variant, it seems like the only early japanese model arcade games to ever escape japan were cocktails.
Level42
« Reply #7 on: February 15, 2008, 09:30:44 am »
Hey Robin ! Yes the Zaccaria cab is pretty much the "standard" Zaccaria cab for a lot of games. See them quite often around here.
The Namco Galaxian cab I linked to was actually built in Italy. So it's not a "real" Namco in the sense that it was built in Japan, but it was licensed. Judging from other pics I've seen (also one in Australia) they are identical however.
My Galaxian (early Midway) is plywood and that wood is still like new....
Level42
« Reply #8 on: February 15, 2008, 10:08:54 am »
Well how about that:
Another Non-Shortened URL!!!!
Terrible pictures, but it's definitely the same cab ! For sale in Germany so it's very very likely a Euro cab ! :)
Looks like this one doesn't have those metal parts on the top....
« Last Edit: February 16, 2008, 01:08:52 pm by Peale »
neokidgeo
« Reply #9 on: February 15, 2008, 03:59:51 pm »
Hi guys,
Thanks for your input  :) Yer they've not had the best of life sad things and they are like an old shed so i'm going to have to be careful when i move them about, I've heard of these new leg levelers that have a coating of some sort on the underneath that makes moving cabs easy as pie but can't find anything about them, be nice to put a set on them for now.
The cabs are held together with coach bolts and them ugly brackets at the top, When i have time i'm gonna see if i can make them more stable, There made from 1/2 inch ply apart from the back two panels and the top panel that are chip board. Are the originals made from 3/4 ply/particle board?
I'm told zac made two diffrent frogger cabs that had diffrent artwork, I have the marquee and cp artwork coming to me in the post so will post a pic when i have it  ;)
UkVacer
neokidgeo
« Reply #10 on: February 15, 2008, 05:28:09 pm »
One of things i was trying to find out about was do original cab front panels go to the floor or do they have kickplates if that's what there called?
And does the top panel go more at an angel or are they like this one with the bracket screwed in to a added piece of wood on the top panel?
Thanks guys  :)
UkVacer
Level42
« Reply #11 on: February 15, 2008, 05:37:14 pm »
Check out my Galaxian thread, there's so many pictures of it , it should answer all your quesitons.
neokidgeo
« Reply #12 on: February 16, 2008, 12:11:44 pm »
Thanks level42, The top panel angle looks different to one i see a few weeks back.
UkVacer
FrizzleFried
    • Idaho Garagecade
« Reply #13 on: February 16, 2008, 01:14:26 pm »
Odd...I have a plywood Ms. Pac sitting in my garage.
Mauzy
« Reply #14 on: February 16, 2008, 05:10:04 pm »
As do I, though it has a particle board back door...
neokidgeo
« Reply #15 on: February 17, 2008, 05:07:00 pm »
Hi guys,
I've been looking at these cabs and pondering how i could make them a bit more stable without making more holes for bolts and screws, so what i'm going to do is insted of replacing the back panels with 1/2 inch particle board i'm going to use 3/4 ply seeing that the sides are ply anyway and add an extra panel to the top, This would mean placing the battons at the back in more and adding battons to the top so that i can remove them horrible clamps.
Now here's the part where i ask for some help from you nice boys  ;D i've looked at jakobuds plans but there's no back plan for the panels and i was just wondering if someone would be able to messure the bottom back panel, the back door and the top back panel please, The top panel i think i'm going to need to find an old damaged marquee and top bracket so i can get the panel angle right as i want the flat panel not the one like in jakobuds plan.
If anyone has a damaged marquee and an old rusty bracket and don't mind sending to london i'd be very greatfull as i know a lot of people don't like sending stuff here for some reason  :-[
Thanks guys  :)
Neo
UkVacer
Level42
« Reply #16 on: February 17, 2008, 05:15:24 pm »
Actually, I've found quite a number of US guys here very helpful in sending/forwarding stuff to Europe.
neokidgeo
« Reply #17 on: February 18, 2008, 02:53:23 pm »
Question on ebay,
Hi do you ship to europe?
Answer,
NO
I think a lot of the times the custom's forms put people off, It's a shame i don't mind send stuff state side or anywhere come to that  :)
UkVacer
Level42
« Reply #18 on: February 18, 2008, 03:39:56 pm »
Yeah, that's true, but you can ask a fellow forum member to help out in such cases.
neokidgeo
« Reply #19 on: February 18, 2008, 03:48:01 pm »
Your right there, I asked a guy on the list who is in new england i think if he could get a sipping price on a cab to south of england and he got it no problem, asked a guy how much shipping would be for some screws on ebay and couldn't be bothered.
Hows your sw doing shauns gonna start on his now his moved to a bigger place.
UkVacer
Level42
« Reply #20 on: February 18, 2008, 05:22:07 pm »
My SW is in a deep wintersleep :)
I fired it up recently to test the extra PCB set I scored on e-bay, still works like a charm.
The plans for my garden/arcade/shed are materialising bit by bit. I think work will start in spring. When it's finished I can finally move all the cabs into it and be able to work on them. And play them of course :)
Shaun's is on the JAMMA+ forum right ?
neokidgeo
« Reply #21 on: February 18, 2008, 06:03:59 pm »
Thats right shauns over at jammaplus, thats who i got these cabs from i swaped them for a midway si shell, sf2 and tetris board.
UkVacer
paigeoliver
  • Awesome face!
« Reply #22 on: February 20, 2008, 02:12:56 am »
Does it have the Pac- curves or the Galaga curves?
