Author Topic: KI2 original arcade problem. (FIXED!)  (Read 1727 times)
amiga500
  • Last login:December 29, 2024, 10:09:10 pm
« on: February 10, 2008, 11:22:17 pm »
Hi,
I get this Killer Instinct 2 original arcade cabinet about a month ago, it is in great shape. today some friends were playing at it and suddenly the game restarts itself, but it keep restarting. It plays the 'boing' sound at the beginning and show the blue screen and then it resets again.
what could be wrong with this??
TIA
« Last Edit: February 11, 2008, 11:34:13 am by amiga500 »
Kajoq
  • Last login:June 14, 2024, 11:28:46 pm
Re: KI2 original arcade problem. HELP!
« Reply #1 on: February 11, 2008, 12:43:57 am »
I had a similar problem on my Super Turbo board one time.
Then I realized I had the cart resting on the Test switch that is on the side of the CPS2 cart.  I dont know what the KI2 board looks like, but you might want to check and see if its not something similar
amiga500
« Reply #2 on: February 11, 2008, 09:59:58 am »
Ok, I'll check that.
I hope that it won't be a serious issue.
thanks
JimmyU
  • Last login:January 31, 2026, 05:24:44 pm
  • I believe I can fly!
« Reply #3 on: February 11, 2008, 11:00:42 am »
Could be a hard drive issue.
amiga500
« Reply #4 on: February 11, 2008, 11:33:39 am »
FIXED!
It was the jamma connector a little loose :cheers:
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
« Reply #5 on: February 11, 2008, 11:34:17 am »
If there was a hard drive problem, I imagine there would be some way to re-flash it using a dumped .chd file or something.
amiga500
Re: KI2 original arcade problem. (FIXED!)
« Reply #6 on: February 11, 2008, 11:35:19 am »
FIXED!
It was the jamma connector a little loose Cheers!
Jdurg
« Reply #7 on: February 11, 2008, 11:38:55 am »
One of the THOUSANDS of benefits of MAME.   :cheers:
Donkey Kong High Scores:
1): 49,500
2): 35,600
3): 30,100
4): 29,400
5): 28,200
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
« Reply #8 on: February 11, 2008, 02:28:16 pm »
Absolutely!  I've rebuilt an Area 51 HD that had crashed with data errors, by using the CHD dump of Area 51. Works flawlessly in the original machine. The other benefit was that it was a slightly newer revision of the software as well  :applaud: :applaud:
Best Regards,
Julian (Fozzy The Bear)
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
