Author Topic: Wiring question  (Read 1246 times)
specksynder
  • Last login:February 20, 2011, 05:31:31 pm
Wiring question
« on: February 10, 2008, 08:44:17 pm »
So my first cabinet is done (almost).  It's a 3-control panel cocktail.  On the long side I cannot fit the 1-player, 2-player arcade buttons after everything else is in place.
I have the small pushbuttons from Happ, but I don't know how to wire them.  The button has 2 prongs on the back.  Anyone know how to connect these to my IPac?
If this makes no sense, let me know and I'll try to provide more info.
Re: Wiring question
« Reply #1 on: February 10, 2008, 08:55:22 pm »
I'm assuming that you have the button shown below.  It looks like a momentary pushbutton (without a microswitch) which would mean that you can connect one end to the ground on the iPac and the other to the Player 1 start button input.  Do the same for player 2.  It does not matter which one you connect to ground or the input.  Momentary pushbuttons do not have a microswitch on them.  Basically, that means that they complete a circuit when pressed.  It would be equivalent to taking a wire that was attached to the ground input and a wire that was attached to the player1 start input and touching them together for a moment.  That would close the circuit and allow the signal to simulate a key press.
Does this make sense?  Let me know if I can explain it better.
~ DeLuSioNaL
specksynder
Re: Wiring question
« Reply #2 on: February 10, 2008, 09:45:28 pm »
That does make sense, and that is pretty much the button I've got.  Thanks for your help!
