Author Topic: Networking question...  (Read 1982 times)
somunny
  • Is it hot in here?
« on: February 09, 2008, 11:46:57 am »
I'd like to run a line from my wireless router (which is connected to a cable modem) to a standard router in my living room and then feed a couple of devices from it.  Can I do this?
Guaranos
Re: Networking question...
« Reply #1 on: February 09, 2008, 12:59:38 pm »
Sure.  You have my permission.   :P
Actually, most home routers and such should allow you to do an uplink, which is what it sounds like you're talking about.  Some have a specific uplink port, but most just let you plug a standard ethernet cable into the first or last port to link them.  I do that in my central wiring panel because I needed 6 ports and had two 4-port Netgears lying around, so rather than spending money on an 8-port or bigger switch, I just uplinked them.
tk_42_1
  • Last login:November 17, 2010, 03:43:24 pm
  • I suggest a new strategy...Let the Yorkie win!!!
« Reply #2 on: February 09, 2008, 01:07:28 pm »
Or instead, use a switch.  That would be cheaper, unless you already have the extra router laying around.
somunny
« Reply #3 on: February 09, 2008, 02:38:26 pm »
Thanks for the advice.  I'll look into a switch as I don't have any spare hardware.
Ed_McCarron
« Reply #4 on: February 09, 2008, 07:09:21 pm »
Oh, and if you DO use a second router?  Be sure to turn off DHCP on the second router if your first router is configured for it.  Use the uplink port as mentioned, not the WAN port.
Samstag
  • Last login:December 16, 2016, 01:41:19 am
  • That's not a llama!
« Reply #5 on: February 09, 2008, 09:22:33 pm »
Keep in mind that unless the second router supports transparent bridging, all your devices will be able to access the internet, but devices on one router will not be able to see devices on the other router (no windows sharing, etc).  Not a big deal for most people.
tk_42_1
« Reply #6 on: February 09, 2008, 09:53:19 pm »
Another good reason to use a Switch.   ;D
BORIStheBLADE
  • Last login:February 03, 2012, 10:53:59 pm
« Reply #7 on: February 10, 2008, 11:34:41 am »
I would go with a switch too.
CCM
« Reply #8 on: February 10, 2008, 02:30:50 pm »
If you don't already have the hardware, I have to echo everyone else, go buy a switch.  Plug it in and forget about it.  No setup or configuration needed for a simple switch.
I have that exact setup here...  cable modem > wireless router > switch
Works great...
somunny
« Reply #9 on: February 10, 2008, 02:37:54 pm »
Okay, so I don't know a whole lot about network switches and such.  After looking around a bit, I found that there's about a million choices.  Anyone have a recommendation?  I'll only be connecting a few devices to it.
EwJ
  • Last login:October 12, 2022, 10:16:06 pm
« Reply #10 on: February 10, 2008, 02:54:32 pm »
I have always had good luck with Linksys devices (using Linksys router and switch right now).
Been mixed results with other -  D-Link, Netgear, etc
zvar
  • Last login:October 08, 2019, 11:39:56 pm
  • One of these days I'll think of somthing cute.
« Reply #11 on: February 10, 2008, 09:27:07 pm »
Another thing you need to be aware of.  Make sure the switch will auto-sense a crossover mode.  If it does not, then you will need a crossover patch cable, instead of a regular patch cable to connect the two devices.
Most devices do auto-sense, but this (2007) holiday season I got a Belkin wireless router and D-link gigabit 5 port switch and one of the two, or both did not auto-sense.
Steven
Ed_McCarron
« Reply #12 on: February 11, 2008, 09:16:33 am »
I always wondered about something.  If you connect two autosense ports together, how do they know which one to start with?
Samstag
« Reply #13 on: February 11, 2008, 09:59:31 am »
They should assume straight-through wiring and go with that.
